05-22-2013, 01:25 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: missoula
| Need some help on a brake line frame I got, it broke
I'm very new to this, I tried mig welding it back on its the piece that goes on shock hoop to hold shock less than 1/4 inch long tubing is 5 mm. I've got more tubing coming ( thanks wife) I have ruined the piece and welded it to screwdriver I had inside to hold it I need some good info guys.
05-22-2013, 05:28 PM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: Vancouver, B.C.
| Re: Need some help on a brake line frame I got, it broke
I use some bricks to hold some of my parts when its too small to be holded by vice grips. Just sandwich your tube between the bricks and then lay the hoop on top with more bricks. At least even if its hard angle to braze, you wont braze the brick to the metal. *Beware, brick stay hot for a long time, wear proper gloves to handle. that's my ghetto trick that has been proven to work. |
05-22-2013, 09:20 PM | #3 |
I didn't have any lube used some flux and ended up just using my iron it gets really hot flowed good not going anywhere
05-22-2013, 10:40 PM | #4 |
| Re: Need some help on a brake line frame I got, it broke I have no clue what you just said...
05-23-2013, 09:15 AM | #5 |
| Re: Need some help on a brake line frame I got, it broke |
05-23-2013, 11:03 AM | #6 |
I doubt that if you solder the part that it will hold. You really need to get the metal red to have a good brazing or else its just like glueing...
05-25-2013, 12:27 AM | #7 |
Need some help on a brake line frame I got, it broke - Similar Threads | ||||
brake line | oscodawave | Newbie General | 15 | 10-09-2010 11:58 PM |
Brake line! | warfile | Tools, and Procedures | 34 | 08-26-2009 03:48 AM |
brake line | grizz | HPI Wheely King | 9 | 06-24-2008 09:35 AM |
brake line ? | nodnarb81 | Tools, and Procedures | 2 | 01-30-2008 10:47 AM |
How much Brake line? | run2jeepn | Newbie General | 1 | 05-30-2006 04:32 PM |
