03-01-2013, 09:51 PM | #1 |
Newbie Join Date: Feb 2013 Location: MEXICO
| Novak goat 3s problem !!! HELP !!!
HI, im having a problem with my novak goat 3tin axial wraith with 3 cell lipo 7.4 volts 5000 mah) when i turn on the ESC and BEC ,the lights and the servo works fine but the motor doesnt work and the ESC stay in red and green leds, i've tried to change de throle profile but the leds stay again in red and green. Can some one help me please |
03-03-2013, 04:38 AM | #2 |
Pebble Pounder Join Date: Jun 2012 Location: upstate,ny
| Re: Novak goat 3s problem !!! HELP !!!
3s is not 7.4v. Make sure sensor wire is pluged in.
03-03-2013, 02:25 PM | #3 |
ho sorry 2s, but the problem is the same, red and green led solid nothing else happen, the only things work are the servo and the lights
03-03-2013, 02:37 PM | #4 |
Did you go back through the "one touch programming"?
03-03-2013, 06:08 PM | #5 |
| Re: Novak goat 3s problem !!! HELP !!! i read de manual and the only thing i found was to pres de botton for 4 seconds and after de 4 leds were on you selected the throle profile 1 or 2 blinking of the 4 leds, does it have another function ? like reset to fabric or somethin like that |
03-06-2013, 04:26 PM | #6 |
here is what it says in instructions(trouble shooting) red&green solid.Check input signal harness connections at ESC & receiver. Check this wiring sequence.-Refer to step 1
Novak goat 3s problem !!! HELP !!! - Similar Threads | ||||
Novak Goat 3S problem | RubiCrawler | Newbie General | 5 | 01-08-2013 07:29 AM |
Novak goat 3s problem | ryno mike | Electronics | 29 | 03-12-2012 12:07 AM |
Novak goat problem | smm_cbf | Electronics | 7 | 06-21-2009 04:36 PM |
Novak Goat Problem... | Centipede | Electronics | 3 | 09-16-2007 06:58 PM |
