miniature tube notcher I have checked most of the tube notching threads and everyone seems to just eye it, with dremels or grinders. Is there a tool out there to properly brace the tubing and get a correct degree set. I would like real tight fits but doing by hand I would image there would always be little imperfections. Has somebody made a jig? or can you buy one? |
A mill works for that. |
I've never seen one for the really small tubing like 1/4 etc. but I know they have them for larger diameters. |
Use a chainsaw file, U can get them in 3/16" and 1/4" make the notch at any angle u like then. Brad. |
Alright I was hoping that there was a tool out there so you can set the angles and clamp the tube in to have an exact angle notch on the tube. Maybe I will see about fabricating somthing. |
i use the tool holder on my lathe and put a 1/4" end mill in the chuck, then put the tube in the tool holder, set your angle, and notch |
a mill would be the most accurate way to do it |
I will definitely try that. |
thats a darn good idea! I was just in the process of trying to build something. |
