09-20-2014, 02:21 PM | #241 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Currently: Face Clearance drill Tap dril ID ID chamfer Counterbore Install clamp OD OD chamfer Switched the ID opps to come before the counterbore. Caused one more tool change but it was worth it. |
09-20-2014, 03:45 PM | #242 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: SMW Shop / My NEW Hobby
So I assume I'm going to have to guess between the dummy screws and the B.L. ring screws?!?! |
09-20-2014, 03:51 PM | #243 |
No. The real beadlock screws line up with the lugs |
09-20-2014, 05:20 PM | #244 |
| Re: SMW Shop / My NEW Hobby |
09-20-2014, 05:43 PM | #245 |
Sometimes you get lucky.
09-20-2014, 06:33 PM | #246 |
09-20-2014, 06:43 PM | #247 |
But all 24 bead holes in the wheel are tapped full depth so you have two backup patterns if it's ever needed.
09-20-2014, 07:06 PM | #248 |
09-20-2014, 07:40 PM | #249 |
No. Just a lot of work!
09-20-2014, 11:12 PM | #250 |
09-23-2014, 02:15 PM | #251 |
09-23-2014, 02:17 PM | #252 |
Pebble Pounder Join Date: Mar 2008 Location: paradise
Hell yeh cant wait to see these in person!!!
09-23-2014, 03:23 PM | #253 |
| Re: SMW Shop / My NEW Hobby I can't wait to finish mounting em up! I agree with Joel(skaldiddog) These should be called the SMW Screw U's. Not too bad though mounting wise, eight bolts per ring and is one of the easiest wheels to mount tires to, that's with C.I. 5.25 wide inners. Thanks again Rob, you made my scale wheel dreams come true! BTW, thanks for sending them fully assembled! |
09-23-2014, 05:06 PM | #254 |
09-24-2014, 03:23 AM | #255 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Wow is all I can say Keep up the hard work there man!
09-24-2014, 07:39 AM | #256 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
"Fresh-dressed like a million bucks, put on my blue lid and my Delrin Chucks." J Dog |
10-03-2014, 11:07 PM | #257 |
So after tapping 1472 holes I had some time to think. How about a direct drive stepper, floating head, cnc tapping machine. From initial calculations capable of tapping a 3mm thread 7mm deep and withdrawing from aluminum in 1 second. Last edited by rob_b; 10-04-2014 at 08:03 AM. |
10-04-2014, 12:21 AM | #258 |
Can we get video of this in action?
10-04-2014, 12:50 AM | #259 |
Started getting measurements for the head casting and spindle. Need to order power supplies, a coupling and possibly material for a mount. Will connect to mach3 with an ethernet smooth stepper for starters. A stand alone controller would be ideal though.
10-04-2014, 08:34 AM | #260 |
Sweet licence plate!! |
SMW Shop / My NEW Hobby - Similar Threads | ||||
Worst hobby shop in town! Franks Hobby hell hole | bolibruch1 | Arizona | 26 | 10-07-2014 06:46 PM |
Hobby shop | 91Bluestreak | Michigan | 3 | 12-21-2011 11:56 AM |
what a hobby shop can do for you? | tubeman | Florida | 5 | 09-24-2008 06:23 PM |
