11-20-2013, 03:10 PM | #1 |
Newbie Join Date: Nov 2013 Location: Edmonton
| Brazing help
Hey all, what do you guys do when you are brazing frames/ chassis? I am looking into getting myself a setup to do some brazing of brakeline and steel rod that is the same thickness of brakeline. Do you guys have a "workstation" setup that is steel or something? I'm looking to use a mapp torch. I got a cheap tubing bender from princess auto (link is below). Would that bender work adequately? Should I pick up a different one from somewhere? Any tips and help would be appreciated. Thanks
11-20-2013, 03:30 PM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: Benicia/Vallejo
| Re: Brazing help
I just used the search function in the tools and procedures section that came up with 193 results for 'bender". why doesn't anybody use the search function? every time you start a new thread about the same thing it makes it harder to find the best thread on the subject.
11-20-2013, 04:29 PM | #3 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: Brazing help
i agree with 1tonscout but here's a couple suggestions for you if you have a bench with a wood top i suggest putting a chunk of steel on the bench first and braze on that. if you have a bench with a metal top already then you can skip step 1. i built a small steel "table" to use for brazing that sits on the wood bench. took a chunk of steel plate, cut 4 pieces of 1/2" square steel tube and mig welded them together. also stay away from gasoline or any flammable things haha.. oh and wear some kind of shaded eye protection (examples-mig welding helmet, oxy/acet welding goggles or dark sunglasses) to keep your eyes from burning |
Brazing help - Similar Threads | ||||
brazing | 76 warlock | Tools, and Procedures | 27 | 05-16-2011 03:14 PM |
brazing | frsttimer | Tools, and Procedures | 5 | 12-02-2007 02:47 PM |
brazing help | johnnyt | Newbie General | 4 | 11-28-2006 04:49 AM |
brazing | gt247life04 | Tools, and Procedures | 5 | 11-27-2006 03:22 PM |
