Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: Daminable solder
Old 10-30-2006, 09:04 AM   #1
Angry Daminable solder
does the temperature of the air effect silver soldering and does the joint have to be smooth before soldering? this weekend i tried puting together my new tuber but i had one hell of a time getting the solder to stick to the brakeline. this is not my first tub truck so i pretty much no how to do everything, i sanded the joints good, used flux, didn't overheat the metal or anything it just didn't want to cooperate. the only things i did different was sand the joints with a cutting bit on the dremel which left them very rough and that it was cold and windy outside when i did it. im gonna grind everything down and start over this week when i find time. does anyone know whats going on?
looneybin is offline   Reply With Quote
Old 10-30-2006, 09:10 AM   #2
For brake line I'm pretty sure your going to want to braze.
86chevy is offline   Reply With Quote
Old 10-30-2006, 10:43 AM   #3
when silver solder/brazing you have to clean the joint with sand paper/emery cloth, then wipe it. apply the flux, heat, then brazing wire.
brazing how-to
http://www.rccrawler.com/tuber.htm
BUBBA069 is online now   Reply With Quote
