04-22-2014, 05:25 PM | #21 |
Rock Stacker Join Date: Mar 2014 Location: Siskiyou County
| Re: cage welding questions
OK,one last mention of CO2 from me. The main cost is buying the bottle,once you own a bottle you just trade your empty for a full then it's around $25 each time.(for a 15 lb.) |
04-23-2014, 04:15 PM | #22 |
Quarry Creeper Join Date: Sep 2010 Location: Gilbert, Az
mg200: very cool stuff!! ...sooooo how did you clean up the welds (if you even needed to!) waffle: thank ya for the info. when able (money) i will follow your instructions i should only be in the garage for my welding so breezes won't be an issue, i will pick up some 0.025 wire & tips too! thanks again guys!!! |
04-23-2014, 11:44 PM | #23 |
I use Argon/CO 50/50 mix .025 I use a 220/240v Lincoln MIG used primarily for my 1:1... a little too heavy duty for micro duties... but welds rod fine. I use carbide bits in my air grinder for grinding down muh booger welds. If I were in the business of it... I get me a TIG |
05-05-2014, 11:02 AM | #24 |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
| Re: cage welding questions Here you go buddy, Ty's chassis' are performers too: Ty's Metal Works Though not all are flux, all the new ones are The super sized Angry Raisin The Raisin 2.1 (X4) and I'm sure there are many others with great looking and performing flux welded chassis. |
02-13-2016, 01:57 PM | #25 | |
Newbie Join Date: Jan 2016 Location: US
| Re: cage welding questions Quote:
Sent from my XT907 using Tapatalk | |
02-13-2016, 02:38 PM | #26 |
Pebble Pounder Join Date: Nov 2013 Location: Bath,ME
I use 75/25 argon/co2 on my welds. For grinding I use a die grinder with 2" twist on pads. Works good for me.
cage welding questions - Similar Threads | ||||
Integy 2.2 roll cage questions | twacrawler | Venom Creeper | 3 | 01-25-2011 12:31 PM |
Tuber Cage and Motor wiring questions | oSPANNERo | Newbie General | 6 | 09-04-2009 12:10 PM |
some questions about brazing gas, soldering\welding and so on... | bazur | Tools, and Procedures | 2 | 06-23-2008 07:55 AM |
Chassis welding questions and thoughts. | Bob-Stormer | General Crawlers | 28 | 02-02-2008 09:53 AM |
