Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: cage welding questions
Old 04-22-2014, 05:25 PM   #21
Default Re: cage welding questions
OK,one last mention of CO2 from me.
The main cost is buying the bottle,once you own a bottle
you just trade your empty for a full then it's around $25
each time.(for a 15 lb.)
4.3 Zook is offline   Reply With Quote
Old 04-23-2014, 04:15 PM   #22
mg200: very cool stuff!! ...sooooo how did you clean up the welds (if you even needed to!)
waffle: thank ya for the info. when able (money) i will follow your instructions
i should only be in the garage for my welding so breezes won't be an issue, i will pick up some 0.025 wire & tips too!
thanks again guys!!!
rc dreemer is offline   Reply With Quote
Old 04-23-2014, 11:44 PM   #23
I use Argon/CO 50/50 mix
.025
I use a 220/240v Lincoln MIG
used primarily for my 1:1...
a little too heavy duty for micro duties...
but welds rod fine.
I use carbide bits in my air grinder
for grinding down muh booger welds.
If I were in the business of it...
I get me a TIG
TacoCrawler is offline   Reply With Quote
Old 05-05-2014, 11:02 AM   #24
Originally Posted by 1tonscout View Post
lets see some pics of a nice flux core welded chassis
Here you go buddy, Ty's chassis' are performers too:
Ty's Metal Works
Though not all are flux, all the new ones are
The super sized Angry Raisin
The Raisin 2.1 (X4)
and I'm sure there are many others with great looking and performing flux welded chassis.
WAFFLE is offline   Reply With Quote
Old 02-13-2016, 01:57 PM   #25
Originally Posted by rc dreemer View Post
THANKS!.. i am having to do the welding so the wife see's me using my christmas gift from her....
as noted above I need to try to use the welder so i can get better at that...
the dremel, cutoff wheels & sanding disks is what i am looking for... i just am not sure of the best to use?
I will check into the ez lock items...., I will get the 025 wire & related feeding stuff as well. Then put to use the info. tips you provided
That is a pretty neat idea... i am going to try to see if i can get the welding down first.. if not then i will conceed to the brazing idea as mentioned above.....
Thanks for all the helpful hints & tools.... all you guys aren't as bad as everyone makes you out to be....
rc dreemer
Sent from my XT907 using Tapatalk
gbolton98 is offline   Reply With Quote
Old 02-13-2016, 02:38 PM   #26
I use 75/25 argon/co2 on my welds. For grinding I use a die grinder with 2" twist on pads. Works good for me.
Kaler is offline   Reply With Quote
cage welding questions - Similar Threads
Integy 2.2 roll cage questions twacrawler Venom Creeper 3 01-25-2011 12:31 PM
Tuber Cage and Motor wiring questions oSPANNERo Newbie General 6 09-04-2009 12:10 PM
some questions about brazing gas, soldering\welding and so on... bazur Tools, and Procedures 2 06-23-2008 07:55 AM
Chassis welding questions and thoughts. Bob-Stormer General Crawlers 28 02-02-2008 09:53 AM
