05-02-2014, 12:06 AM | #1 |
Quarry Creeper Join Date: Apr 2014 Location: USA
| Mini extractor set?
So my wife is "helping" me build my Wraith kit. Well driving the bolts to hold the diff cover into the axel housing is pretty tough. Since we're sharing tools she must have had a worn bit and it started slipping and stripped the hex head. So the screw is all the way in now and piece mounted but I would really like to replace that bad screw. I'm sure down the road I'll upgrade or need to get in there to do some repairs. I saw a mini extractor set on Amazon for like $25 that got decent reviews. Sounds like it is more for watches and computers but it still might do the job. So, what do you guys recommend? PS: I tried about every bit I have, even a torx but I have nothing that will bite (plus it is a tight fit, taking decent force to drive it in so I don't expect it to come out too easily). Couldn't get needle nose vise grips on it either. I know down the road I could remove the other bolts and man handle the cover to get at it or even just cut the head off but I'm far from that point right now. |
05-02-2014, 01:01 AM | #2 |
| Re: Mini extractor set?
You should be able to grab it with a pair of dykes and turn it back out.
05-02-2014, 08:31 AM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
what about driving a bigger hex into it with a hammer ??....
05-02-2014, 09:24 AM | #4 |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
Diff cover bolts use a 1.5mm hex driver, when they strip use a 1/16 hex driver in place, works perfect and will get it out so you can replace it Get this tool set, best hex drivers for RC: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKTP2 These tools are quality and wont strip out your hardware. Last edited by WAFFLE; 05-02-2014 at 09:30 AM. |
05-02-2014, 12:36 PM | #5 | ||
| Re: Mini extractor set? Quote:
Hadn't thought about that. I could try that. Not sure there is much left to grab though Quote:
Thanks for the link. I actually have a good set of Hex wrenches that fit real nice except we were working together so she was using some cheap ones. Then once it started it was most of the way in. I should have backed it out right then but since it was so close and I wanted to "finish" the part I drove it in not out . Hindsight is 20/20, I should have taken it out while there was still some edges to grab. It is quite rounded now . | ||
05-02-2014, 03:30 PM | #6 |
Use a 1.5mm throwaway Allen, then fill the head with jb weld, insert Allen. Let dry/cure and remove.
05-02-2014, 09:26 PM | #7 |
Take your dremel tool and cut a slot into the head of the bolt, then use a screw driver and back it out with style! |
05-03-2014, 12:34 PM | #8 | ||
Also a decent smaller size back out set has helped me, basically smaller left hand drill bit and left hand tap. Has got me out of a couple situations. | ||
05-03-2014, 12:58 PM | #9 |
Thanks guys. Great idea on the JB weld. Was almost at the point of trying the slotting method too. I finally did manage to grab it from the side with some needle noses and get it out. I think I will get a small extractor set just to have because someday it may save me and I'd hate to really need it and not have it. I've seen this one Alden 4507P Micro Grabit Broken Bolt Extractor 4 Piece Kit - Threading Tap Extractors - Amazon.com but it only deals with 3mm on the small side. Then there is this one that has the appropriate mm sizes but not sure it'll work on the hexes: Amazon.com: Moody Tools 58-0670 6-Piece Slot/Phil/Screw Extractor Combo Reversible Driver Set: Industrial & Scientific. Thought? |
Mini extractor set? - Similar Threads | ||||
Stripped Hex Screw - Craftsman Screw Extractor | bigstu | Tools, and Procedures | 8 | 11-05-2011 08:48 AM |
screw extractor bit ? | Aggie01 | Tools, and Procedures | 4 | 02-05-2011 02:18 PM |
The 'Tooth Extractor' version 2.0 Action Photos(56k warning!) | gregrocks90046 | Tamiya TLT Crawlers | 15 | 04-20-2005 06:53 PM |
