05-14-2014, 06:25 PM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Houston
| Screw Extractor
Looking for some guidance on an extractor tool for a M2 X 10mm hex cap screw. I stripped the head out when it was about 90% screwed down. I tried the trick of driving a torn into it to back it out, but only was able to back it out a little ways before it stripped to the point where that method didn't work. The screw is about 70% down now. It's one of the screws on the diff cover on the Wraith that I'm building, so it's too close to the cover to be able to grab it and try to turn it with needle nose pliers or anything. Any advice would be appreciated. |
05-14-2014, 06:37 PM | #2 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
Try taking a dremel or something similar and cutting a slot in the head of the screw with a cutoff wheel and using a flat head screwdriver to get it out. Sent from my Phoneamathingy |
05-14-2014, 09:51 PM | #3 |
| Re: Screw Extractor
I've used that method in the past. The problem is that the head of the screw is right by the outer wall of the VP diff cover. I can't get in there to slot the cover without cutting into the cover - something i would like to avoid. I have the smallest EZ out and Grab-It bits they make, I think. Still too big to get it.
05-15-2014, 03:19 AM | #4 |
Quarry Creeper Join Date: May 2009 Location: India
| Re: Screw Extractor
post some pics if its not too much to ask , in order to get the right guidance.
05-15-2014, 09:30 AM | #5 |
| Re: Screw Extractor
Have you tried using a torx? sometimes you can jam one in enough for it to grab. You might also try heating it a bit with a soldering iron, but be careful if the housing is plastic.
05-15-2014, 11:12 AM | #6 |
| Re: Screw Extractor
I'll post up some pics tonight. I did try a Torx and that's how I was able to back it out a little before it stripped some more.
Screw Extractor - Similar Threads | ||||
Mini extractor set? | IPT | Tools, and Procedures | 8 | 05-03-2014 12:58 PM |
Stripped Hex Screw - Craftsman Screw Extractor | bigstu | Tools, and Procedures | 8 | 11-05-2011 08:48 AM |
screw extractor bit ? | Aggie01 | Tools, and Procedures | 4 | 02-05-2011 02:18 PM |
Where do you get you screw(s) | Yama-Bro | Chit Chat | 17 | 01-17-2008 08:32 AM |
The 'Tooth Extractor' version 2.0 Action Photos(56k warning!) | gregrocks90046 | Tamiya TLT Crawlers | 15 | 04-20-2005 06:53 PM |
