Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: how do you C notch your tubing
Old 11-14-2006, 10:37 PM   #1
I'm a stupid C U N T!
slobin3d's Avatar
Default how do you C notch your tubing
I'm trying to build a tube scaler I was wondering what everyone uses to C notch their tubing. I am planning on using 3/16 brake line and brazing. And what do you use to clean up the slag from brazing?
slobin3d is offline   Reply With Quote
Old 11-14-2006, 10:52 PM   #2
i was gonna try one out of 1/4", i bought some 1/4 bits for my dremel thinking i could easily notch em, but nope. i think a how to i read though notching with the 3/16 wasnt as important cause when you braze it fills it in, that you could just kinda v-notch it. with scale tubers on the rise it would be nice if they came out with some scale size tubing tools....
Thorsteenster is offline   Reply With Quote
Old 11-15-2006, 01:55 AM   #3
Use the corner of a grinding wheel.
Old 11-15-2006, 02:10 AM   #4
OG Green Meat Star Man
young_version's Avatar
i use a 3/32 drill bit and drill out the center or what size bit you need,depending on what size tubing,if the fishmouth is too big just smash it with a hammer or grind away what you dont need.works pretty good.
i recently was reminded about this technique from o5tacoma. commonly used for making tube chassis' for drag racing.if you dont have a tube notcher.
young_version is online now   Reply With Quote
Old 11-15-2006, 02:58 AM   #5
So you figured that out too? It works great.
BlueMonster is offline   Reply With Quote
Old 11-15-2006, 04:11 AM   #6
MWRCA'er
Mnster's Avatar
Mill, Dremel with the tiny sanding drum, rat tail file.
Mnster is offline   Reply With Quote
Old 11-15-2006, 04:50 AM   #7
If you see here there is many ways to do it. Also if you use 3/16 solid rod and MIG weld there is no need to notch anything. Since both metals are melted at the joint.
Old 11-15-2006, 08:01 AM   #8
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
It's best to make a decent fishmount so you get a good fit for brazing.
I've actually found the fastest way to fishmouth is with an abrasive 7" steel blade I have in a table saw. After that I hit it a bit with a rat tail round file.
If you don't cook the flux too much it comes off pretty easy with some Scotchbrite, or you may have to sand a bit if it's gotten too hot. If you wait about 30-60 secs for the joint to cool a little and then douse it in water, a fair amount of time a lot of it will wash off.
Jay
roktoy is offline   Reply With Quote
