08-31-2014, 09:28 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Axial universals repair
I ordered a new set of XR10 uni's for a scaler mod and one of them came really tight. So tight that I used a flat blade screw driver to try to open up the ears on the main shaft. With a light bump of the heal of my hand, the ear snapped. Has anyone tried to repair this problem??? I don't have access to a welder, but I do have a mapp/oxy setup. |
09-01-2014, 01:17 AM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Australia
| Re: Axial universals repair
I don't like your chances welding them prob just put and ad in wanted for the side you need
09-01-2014, 02:54 PM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
yeah I repaired mine with MIP shafts ....
09-01-2014, 03:59 PM | #4 |
I'll look into MIP. Didn't know they made them. Thanks. |
09-01-2014, 04:03 PM | #5 |
I still would like to know if the stock uni's are repairable.
09-01-2014, 06:18 PM | #6 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
If they are so brittle that they broke with a little prying, they would never survive welding. Best bet would be to call or email Axial. They might have mercy on you and send you out the broken part.
09-01-2014, 09:25 PM | #7 |
Apparently your not clear on my problem. One of the tabs/ears broke off the main shaft.
09-01-2014, 10:00 PM | #8 | |
Quarry Creeper Join Date: May 2008 Location: Tennessee
| Re: Axial universals repair Quote:
Here you go check this out. Maduff's Mutt from CCC | |
09-01-2014, 10:39 PM | #9 |
Thanks Bigron. I'll do a thought reading. |
09-02-2014, 11:35 AM | #10 |
When I was narrowing a set of AR60 axles for a 1/6th Jeep build, I snapped off an ear for the u-joint, just as you described. I used an Oxy/Acetylene torch and silicon bronze rod to re-attach it. I only drove the Jeep maybe a dozen times before selling it, but the repair held, much to my amazement.
09-02-2014, 11:37 AM | #11 |
brazing would be the way to fix it without risking stress fractures from the heat affected zone of welding. Silicon bronze or silver braze filler would likely be the best choices.
Axial universals repair - Similar Threads | ||||
axial universals...really worth it? | mr lee | Axial SCX-10 | 18 | 12-25-2013 12:05 PM |
Axial Universals | sally1800 | Axial Wraith | 14 | 08-08-2011 05:23 PM |
