| | #1 |
| Newbie Join Date: Nov 2006 Location: San Mateo
| I see that every one says that silv 56 is the best brazing rod. But I cant figure out where to buy it. Any sugestions? Does it have to be a welding shop? Sorry if its alreay been said but I coulnt find it. Also when making a tuber what is the best way to make shock mounts? Can you attach sheet metal with brazing? Sorry im new at this. Thanks for the help! Sean |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| 1yes 2 sheet metal, washers all have been used for shocks. |
| | #3 |
| RCC Addict ![]() Join Date: Sep 2005 Location: Behind the torch!
| I just started brazing, and I couldn't find silv 56 nowhere. When I asked the guys at hardware shops they looked at me as if I made it up. So I just used regular brazing rod with a hand held Mapp torch. Worked pretty good for me. If you have an oxy/acty setup I was told that you can use hangers. |
| | #4 |
| Thanks For The Help!!! And by the way does anyone know if the LRP Runner Plus Reverse work with a dual motor and 4ws set-up. here is a link to the specs. http://www.lsarc.com/forums/showthread.php?t=29 Last edited by gt247life04; 11-27-2006 at 09:27 AM. |
| | #5 |
| Rock Crawler Join Date: Sep 2006 Location: Esco.
| I got mine thru Airgas, 25 bucks(ouch) but it is super easy to use. |
| | #6 |
| I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| You can braze sheet metal with safty silv. Here is a link to where to order it on line. Harris SAFETY SILV.. Where to get it. |
| Thread Tools | |
| Display Modes | |
