Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: aluminum tubing?
Old 12-02-2006, 12:45 PM   #1
Default aluminum tubing?
hello does anyone have any info on aluminum tubing? how to weld/braze? the strength of it? i have tried to use durafix. that crap makes it look easy to use and strong on the net but its not. i was gonna use the tubing for a tuber chassis hybrid. i know your gonna ask why aluminum? because i need to connect it to aluminum that is a part of my running gear off a revo
SLIPPERYNOVA is offline   Reply With Quote
Old 12-02-2006, 06:04 PM   #2
You can braze aluminum, if mixed with Argon gas. It's dangerous because it removes the oxygen from what I understand. There has got to be a way to attach the Revo parts to steel.
BlueMonster is offline   Reply With Quote
Old 12-03-2006, 01:56 PM   #3
TIG welding is the best, but is truly an artform to accomplish so that a chassis appears "correct" at the joints. Aluminum rod is easiest to work with, and the weight is very low, as demonstrated in table below.
ALUMINUM 6061 ROUND ROD
Size------------Approx. Wt. Per Lin Ft
1/8------------ 0.015
3/16----------- 0.032
7/32----------- 0.044
1/4------------ 0.059
5/16----------- 0.090
3/8------------ 0.133
7/16----------- 0.178
1/2------------ 0.235
Hope this is helpful, Kerry
kerrywittig is offline   Reply With Quote
Old 12-04-2006, 07:43 PM   #4
ok yea if u dont want 2 weld it u can braze it but with argon gas am i rite???
zeke67 is offline   Reply With Quote
