Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Removal of rounded set screw?
Old 02-15-2015, 09:22 PM   #1
Default Removal of rounded set screw?
I was going to replace my cheap plastic drive shafts with some punishers and found two set screws that are wanting to round off. Is there any tricks to getting these out without tearing up to much sh!t? The drive shafts are on my TF2. I changed one shaft with no problem.
Crutch is offline   Reply With Quote
Old 02-15-2015, 09:28 PM   #2
Default Re: Removal of rounded set screw?
Use a Dremel cut a slot use a flat head screw driver or use a solder gun heat it up and use good hex driver that's prefibly new if it's not to stripped
jdmguy760 is offline   Reply With Quote
Old 02-15-2015, 10:51 PM   #3
Take a read through this thread......there were some pretty good ideas passed around.
sripped set screw
Revoasian is offline   Reply With Quote
Old 02-16-2015, 05:47 AM   #4
Thanks for the link Revoasian. It has some helpful info in it.
Old 02-17-2015, 05:29 PM   #5
Have you tried an easy out?
devinbrown07 is offline   Reply With Quote
Old 02-19-2015, 08:27 PM   #6
i put the hex bit in then put solder around it and boom comes right out
arcanecrawler89 is offline   Reply With Quote
Old 02-20-2015, 05:54 AM   #7
I dont have an easy out to try at the moment. I like that soldering idea, I may try that tonight. Thanks guys...
Old 02-25-2015, 12:32 PM   #8
Easy out×2 should come rite out
cobaltracer1986 is offline   Reply With Quote
Old 02-25-2015, 08:42 PM   #9
Could use a left hand drill bit too. Next time use quality tools and this wont happen again.
Lentsnh2012 is offline   Reply With Quote
Old 02-25-2015, 09:01 PM   #10
I've had decent luck using a torx drive one size up...cuts into the corners of the rounded out hex.
MountainStorm is offline   Reply With Quote
Old 02-25-2015, 09:32 PM   #11
I have also had good luck with torx bits on striped hex head screws, a little heat from soldering iron helps sometimes if loctite is involved .
I use this trick almost every day at work as powersport tech
ossipeesummit is offline   Reply With Quote
Old 03-01-2015, 09:03 PM   #12
left hand drill
JeepinDoug is offline   Reply With Quote
Old 03-23-2015, 12:58 AM   #13
For me it depends on the size of the set screw. I strip out alot of 1.5mm set screws and find that a 1/16" hex fits in it great everytime. For other screws i try either a torx or a larger hex with solder. If that doesn't work then a left hand drill. Worst case senerio's require retaping for a larger set screw. Like others have already said a easy out should work great on a set screw the tips on mine though dont get small enough for some of the smaller screws.
crawlerwon is offline   Reply With Quote
Old 04-09-2015, 10:32 PM   #14
I just finished having to drill out a set screw for a young fella.
Start with a drill equal to hex wrench.
Drill nice and straight and be prepared the break bits.
Increase drill size until just the threads are left.
Or send it to me
crashtestheli is offline   Reply With Quote
Removal of rounded set screw? - Similar Threads
tips to remove rounded set screws? brianw Tools, and Procedures 2 03-08-2014 02:02 PM
Need Screw Removal advice. WestTxRc General Crawlers 16 10-26-2011 04:21 PM
~TSS~ GIVEAWAY! Ultimate Set Screw 3mm Set! STANG KILLA SS General Crawlers 78 09-10-2011 07:40 PM
set screw help Coffinspire15 Tools, and Procedures 6 05-30-2011 05:04 PM
Rounded Axle set screws Kanine38 Axial AX-10 Scorpion 9 09-09-2010 11:58 PM
