02-13-2007, 04:14 PM | #21 |
Rock Crawler Join Date: Jul 2006 Location: Northeast
I just picked this one up for $63 on closeout . I went in for a scroll saw but couldn't resist . http://www.sears.com/sr/javasr/produ...bcat=Band+Saws |
02-28-2007, 07:47 PM | #22 |
Rock Crawler Join Date: Apr 2006 Location: Pineville Ky
Thats a good deal on your band saw ive been thinking about picking up one for myself. where can i find the delta brand? |
03-05-2007, 11:55 PM | #23 |
Newbie Join Date: Oct 2005 Location: FREMONT
| http://www.grizzlyimports.com/ they have some good deals and quality products. much nicer than harborfreight |
03-07-2007, 03:21 PM | #24 |
Thanks urbnflx i checked out the website and ordered a free catalog. |
03-12-2007, 11:53 AM | #25 | |
Rock Crawler Join Date: Dec 2005 Location: Marietta
03-15-2007, 02:36 PM | #26 | |
on another note, i was down at lowes yesterday and saw the small delta bandsaw. i looked for metal blades and couldnt find any. is there a place that sells them? | |
03-21-2007, 09:17 PM | #27 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
i beleive you can find metal band saw blades on mcmaster....
03-22-2007, 05:52 AM | #28 | |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
03-22-2007, 01:46 PM | #29 |
cool, i was doing a bit of research on 9-10 inch saws last night on the net. i found this one: http://www.northerntool.com/webapp/w...7283_200327283 Made by kawasaki. It says it comes with a laser guide and a light. Where i will be putting the saw i could use the extra light. Does anyone know if there tools are worth the money? i am trying to decide on which saw to buy in the 99 dollar range. BTW McMaster does have blades for all the small saws. |
03-26-2007, 11:02 PM | #30 |
found a real nice saw from crapsman. 10 inch all cast iron table. it even has ball bearing guides. http://www.sears.com/sr/javasr/produ...seBVCookie=Yes a little bit more expensive but it looks like its worth the money over the delta and the ryobi. Last edited by URBNFLX; 04-06-2007 at 09:57 PM. |
03-30-2007, 08:45 AM | #31 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
The rpm's on wood cutting band saws are about 10 times too fast for metal, but a lot of guys use them with success. Heat is what kills the metal cutting blades. High speed Bi-metal blades will hold up much better. I picked one up from a tool center locally for 15.00 I was paying 10.00 for the carbon ones. A fine misting of water from a spray bottle will help keep the blade cooler while cutting. I have a Craftsman band saw and have no complaints except I wish I would of got one with the shop light attached. -MikeP Last edited by Mike Poulson; 03-30-2007 at 08:48 AM. |
04-06-2007, 10:06 PM | #32 | |
04-06-2007, 10:14 PM | #33 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Cheaper wood cutting band saw + appropriate amperage speed control = cheap metal cutting band saw. At least this is my theory. If I get power out to my shop in the next couple of days, I will see if it really works. |
04-18-2007, 11:36 AM | #34 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I know from long experience that the cheaper benchtop bandsaws are generally designed for woodworking - so you have to deal with excessive blade speed and the lack of good metal blades that will fit. There are ways to slow the motor speed, but if you can't find a good blade it's a moot point. I had a Delta for a while, I got tired of searching for blades. I got one of these from my dad. Not cordless though, an old-school one you have to plug in: I replaced the small black stop with a 1/4" 6061-T6 "table" for more work area. I clamp it in my bench vise when I need to use it. Blade speed is like a third of a "hobby" bandsaw so heat buildup is not such an issue, and replacement blades are readily available and last forever practically if used properly. They're pretty expensive new, 400 bucks or so. If you could find one at a pawn shop or something you might get off cheaper... Last edited by Big Mike; 04-18-2007 at 11:39 AM. |
04-18-2007, 11:46 AM | #35 | |
04-18-2007, 11:59 AM | #36 |
Adilynsdad too! Join Date: May 2004 Location: G ville
Ben, you have pm
04-23-2007, 10:34 PM | #37 |
RCC Addict Join Date: Nov 2005 Location: Utah
04-24-2007, 07:30 PM | #38 |
04-24-2007, 08:01 PM | #39 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
ryobi will hold a bigger (wider) blade than the delta; a little more for metal cutting. although neither is really suited for it.
05-01-2007, 06:11 PM | #40 |
DO NOT BUY THE RYOBI. i have one it blows, not even usable. in fact if you can cut a straignt line ill give you $100. i tell you what, you come get it, its yours!
