Thin 7mm socket for hub/wheel nut? So I bought a set of used beadlock wheels. The problem is I can't find a socket that is small enough on the outside to fit. I files my plastic wrench that came with the kit. But it seems that one is slipping now. |
Re: Thin 7mm socket for hub/wheel nut? Depends on the size of the axle nut. Grind down a 7mm socket to fit. It will be super close to fitting/taking too much socket material. I found and use a 7mm orange handle 7mm O'Donnell driver that fits. Or http://www.rccrawler.com/forum/enrou...ml#post2701203 Maybe? SWorkz SST 7mm Nut Driver [SWX-620010] | Maintenance - AMain.com - AMain.com |
Re: Thin 7mm socket for hub/wheel nut? I use one of these wrenches: Thunder Tiger Cross Wheel Wrench & Fuel Tubing [TTRPD1974] | Maintenance - AMain.com - AMain.com It fits inside a SLW hub with no mods so it should fit most other wheels. |
Re: Thin 7mm socket for hub/wheel nut? I use a Duratrax 7mm nutdriver on metric wheel nuts, but this Dynamite driver looks much thinner and the Duratrax has been discontinued. Dynamite 7mm Machined Nut Driver [DYNT2014] - AMain.com I've occasionally used this Craftsman nutdriver too. Craftsman 7mm nutdriver - Sears.com And Associated has this 7mm T-handle wheel nut wrench. Team Associated 7mm FT T-Handle Nut Driver [ASC1569] - AMain.com |
Re: Thin 7mm socket for hub/wheel nut? I almost wonder if there's a smaller size nut that would still fit the threaded shaft. |
Re: Thin 7mm socket for hub/wheel nut? Quote:
according the wraith manual the axle nut is a m4 nylon lock nut. fastenal has these https://www.fastenal.com/products/de...L2530000A20000 8.25 for 50 |
Re: Thin 7mm socket for hub/wheel nut? Vanquish has one too 7mm Modified Nut Driver - Vanquish Products |
Re: Thin 7mm socket for hub/wheel nut? I bought this wrench from Yeah racing. Never been a nut driver fan, hard to get enough torque through a screwdriver handle. Wanted something similar to the big wrenches for 1/8 scale buggy nuts and better than a kit wrench so far pretty pleased. http://i3.photobucket.com/albums/y72...pss3ngrxro.jpg http://i3.photobucket.com/albums/y72...psx8mmgkyp.jpg |
Re: Thin 7mm socket for hub/wheel nut? i ended up picking up one of these kits with my latest rpp order because i was sick of dealing with crappy harbor freight tools https://www.rpphobby.com/ProductDeta...tCode=KXST0051 i know you are just looking for a solution for axle nuts (which this has) but its everything you would need in one handy little case :) |
Re: Thin 7mm socket for hub/wheel nut? I'm always into spending money, but couldn't you guys just buy the cheap traxxas cross-wrench/wheel-wrench. I got one with my mini-erevo, been using it for my SLWs with no issues. If you check eBay they even come with the rest of the Allan keys that every other traxxas what-have-you comes with. |
Re: Thin 7mm socket for hub/wheel nut? here are two from ebay, one used, one new these are 7mm deep sockets. the ends are pretty thin. good luck Matco Tools 3 8" Drive 7mm Deep Socket 6 Point BD7M6A Metric Made USA | eBay Proto J5007M Socket 3 8 in Dr 7mm 12 PT Deep | eBay or there are a couple of sets of the deep sockets but why? |
Re: Thin 7mm socket for hub/wheel nut? I have the Losi branded version of this which is little bit nicer, they are both hex drive, 8-in-1 Hex Wrench Kit | HorizonHobby THen I bought Team Associated socket drivers to go with it, great trailing/crawling tool in your pack or pocket to reduce weight carried with you and very high quality. They have metric and sae, thinwall sockets and other drivers. :) https://www.teamassociated.com/parts/tools/ |
Re: Thin 7mm socket for hub/wheel nut? I took my fat one to the bench grinder, then it was skinny. |
Re: Thin 7mm socket for hub/wheel nut? 1 Attachment(s) I use a Team Associated 7mm nut driver bit in my Makita electric screwdriver w/ clutch. Automatically kills power when it's tight. Also works great on my yeti bead locks. |
Re: Thin 7mm socket for hub/wheel nut? I use protek rc nut drivers, haven't had a problem with the 7mm not fitting anything yet. ProTek RC "TruTorque" Metric Nut Driver (7.0mm) [PTK-8226] | Maintenance - A Main Hobbies - A Main Hobbies |
