Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: Badger 155-1 AirBrush Kit
Old 12-30-2006, 10:20 AM   #1
Default Badger 155-1 AirBrush Kit
My old Air Brush after 10 years of use finally broke.
150 Badger
http://www2.towerhobbies.com/cgi-bin...?&I=LX8154&P=6
This time I went with a different set up. Should work the same as my old one but as some grip to it. 155-1 Badger
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LX8155
As anyone used this one? And what was your likes and Dislikes?
run2jeepn is online now   Reply With Quote
Old 12-30-2006, 11:24 AM   #2
bRIBEGuy's Avatar
I've been using the 155 Anthem for 2+ years now and I love it.
As long as you clean it after every use, it's very versitile and accurate (but really, that goes for any airbrush...). I find thicker paints like Parmas's Fastcolor work best in it if you thin them a bit first, though.
Here's a few bodies I've done up with mine so far:
bRIBEGuy is offline   Reply With Quote
Old 12-30-2006, 11:53 AM   #3
i like the iwata eclipse.it sprays realy nice.i do a lot of helmets and it works fine for that..great for what we do on r/c's.and not that expensive ...$77.00 at jerry's artarama.
JEFF THE JET is online now   Reply With Quote
Old 12-30-2006, 01:26 PM   #4
with Badger in the name it HAS to suck.
Unholy is offline   Reply With Quote
Old 12-30-2006, 04:58 PM   #5
OCCUPY RCC!
dezfan's Avatar
Not really, only good thing I ever had w/ Badger in the name was my Badger airbrush.
Resently sold it to Double J!
dezfan is online now   Reply With Quote
Old 01-08-2007, 03:19 PM   #6
Well I just got it today. Can't wait to test it out.
Old 01-09-2007, 07:55 AM   #7
Whats the difference between the Badger Crescendo(175) and the Anthem(155)? The Crescendo was recommended to me as a good airbrush to start with. I'm trying to decide what to get so I've been taking a look at a lot of brushes lately and this is the first time the Anthem has been mentioned.
Thanks,
Tom
metomwhou is offline   Reply With Quote
Old 01-09-2007, 09:09 AM   #8
The 175 is more of a pro style brush, has differant nozzle/needle for fine/med/heavy settings. The 155 has a single nozzle/needle setup witch is nice when you are starting out.
I use a 100G, its a gravity fed dual action.
BUBBA069 is offline   Reply With Quote
Old 01-09-2007, 01:08 PM   #9
I'm a stupid C U N T!
slobin3d's Avatar
i have an anthem 155. caept mine is all silver. Its a great airbrush the only thing it doesnt have is different needles. it comes with a medium tip and thats all you get.
slobin3d is offline   Reply With Quote
Old 01-10-2007, 06:34 AM   #10
Thanks for info guys! I think I'll probably pick up the Crescendo, since they're around the same price. Hopefully I can learn with it and grow as needed.
Tom
Old 01-10-2007, 08:25 AM   #11
Can't you change needles. I have 3 other sizes from mt last Badger. Why wouldn't they fit. Also mine is all Silver.
Old 01-10-2007, 12:53 PM   #12
Gold Star Baby!
I still have my 150IL from back in the day along with my 200 and Paasche H...thinkin about pickin up a Iwata HP-CS.......
NorCal 2500HD is offline   Reply With Quote
Old 01-10-2007, 06:39 PM   #13
slobin3d's Avatar
the anthem uses a special needle and tip that is made only for it. as far as ive seen theres no other needles available for it. http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
dont let that stop you from getting one though, there great airbrushes and for most of the stuff we do it wont have a problem. unless you want to paint a 1:1 car or do nails
Old 01-11-2007, 06:27 AM   #14
Try DixieArt guys, they're a little better on price and seem to be good folks according to a few guys that recommended them to me.
Check it out. http://www.dixieart.com/Badger_155_A..._Airbrush.html
Tom
Old 01-14-2007, 01:17 PM   #15
Tom
I have also used Dixie Art in the past. They are great!
Trikster is offline   Reply With Quote
Old 01-14-2007, 04:57 PM   #16
slobin3d's Avatar
well i did some diggin around on the net and found that theres a fine spray kit thats available, it requires a new needle, nose cone, and regualtor. Strait from badgers site....*OPTIONAL PARTS FOR FINER SPRAY. PART # 41-033 REGULATOR, PART #51-81DT NEEDLE, PART # 41-003 PAINT TIP
Also in addition to having to clean it after every use, like any airbrush, theres a small teflon bushing that is inside the barrel of the airbrush that needs to be lubricated on occasion, when spotting or pulsating is noticed. I wipe the needle with a little carnuba wax the slide it in and out of the barrel a few times till it rides smooth again, then wipe up the excess, Then I run some water through it to clear out any leftover wax. Viola runs like brand new!!!
Old 01-15-2007, 10:44 AM   #17
the badgers a good kit
rian is offline   Reply With Quote
Old 01-15-2007, 10:59 AM   #18
Nice tip on maintance....Thanks
Old 01-15-2007, 04:07 PM   #19
slobin3d's Avatar
they draw paint up through the tube, it doesnt really matter. bottom feeder usually hold more paint though.
Old 01-15-2007, 04:11 PM   #20
Does anybody know if a internal mix brush sprays any different than an external mix?
kerosinek is offline   Reply With Quote
