Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: c-channel cutting
Old 01-04-2007, 08:28 PM   #1
I had the hottest girlfriend at the MSD Nats
Default c-channel cutting
whats the best way to cut 1/2 steel square tubing to make c-channel frame rails? i was thinking an angle grinder and a cutoff wheel. im sure theres a better way. should i bend it first or cut it first? thanks for the help and if theres any other trick let me know! thanks again
obijuan is offline   Reply With Quote
Old 01-04-2007, 10:40 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
bend it all up first, drill your holes so they will be even on both sides. Then take a measuring tape/ruler/whatever, then put teh marker on the 1/4" mark and push the tape and marker all the way down the tube. That way the line is straight and even. then use the cutoff wheel and follow the line
TwistedCreations is offline   Reply With Quote
Old 01-04-2007, 11:11 PM   #3
Ace
I used my metal cutting bandsaw. Worked a treat.
Ace is offline   Reply With Quote
Old 01-13-2007, 07:24 PM   #4
X2 on the bandsaw. Mine was about the best $150 I have ever spent.
GA Dawg is offline   Reply With Quote
Old 01-13-2007, 07:34 PM   #5
yeppers i did it and it looks well, pretty good! but needs a little grinding for small wavyness but thats just my ocd talking. i welded the ends back together adn in the middle and am going to bend it when i get my body all worked together. thanks for the good idea!
