02-14-2016, 07:20 AM | #21 | |
| Re: craftsman lathe 109 Quote:
02-14-2016, 07:28 AM | #22 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
I bought the lathe but won't be able to even touch it till may.thank you guys for all the info on dro's.
02-14-2016, 12:08 PM | #23 |
| Re: craftsman lathe 109 While I never doubted you, I'm surprised at how different those handles look compared to the one that I use. Ill click a pic the next time I'm at the shop. |
02-14-2016, 12:15 PM | #24 | |
I've been buying them off of ebay for $10-$15 dollars and they're perfectly adequate for most things. I have noticed that the fit/finish isn't always nice, but a little disassembly and cleanup with a scotchbrite and some lube does wonders for them. | |
02-14-2016, 05:05 PM | #25 | |
RCC Addict Join Date: Oct 2009 Location: San Francisco
02-14-2016, 05:24 PM | #26 | |
Quarry Creeper Join Date: Jul 2015 Location: Hanover
neat trick. | |
02-14-2016, 05:45 PM | #27 |
| Re: craftsman lathe 109 not from what I have seen. Only side-effect i that it will magnetize them and that means they turn into a porcupine pretty fast but other than that I haven't seen any issues. Sure a dial indicator with a clamp is nice but for the ultimate in ease I don't think it gets much simpler than that mind you the calipers are HF cheapos |
02-14-2016, 05:48 PM | #28 | |
I'm sure they exist, but outside my budget... | |
09-29-2016, 07:53 AM | #29 |
| Re: craftsman lathe 109 |
09-29-2016, 11:17 AM | #30 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
I'm jealous, I'd love to have a little bench top lathe in my shop to turn parts on, then again I dont know what all I would use it for haha.
09-29-2016, 11:29 AM | #31 | |
I don't know if someone took this apart before or not, but there's a lot of paint and crap that needs to be cleaned up. | |
09-30-2016, 12:01 PM | #32 |
I lapped the surfaces on a piece of glass with some wet sandpaper. I wasn't trying to get things super smooth...I just wanted paint free flat surfaces. I also wanted to make sure the top slide base was parallel to cross slide so I chucked it up on the lathe. I faced a piece of square stock in the 4 jaw and held the base tight with a live center in the tail stock. I was taking very light passes so I figured this would work and it did: I used a triangular file to clean out the way areas as well. I didn't want to remove much material, just clean them out and file down any burrs that were left behind. You can see a pretty large void left behind in the casting. It slides much smoother now. |
09-30-2016, 09:45 PM | #33 |
Looks good to me I would not worry much about the void in the casting, if anything stick some grease in there and call it good its always cool seeing people restoring old machines... even if their not super useful the historical and sentimental value makes it worth it!
10-05-2016, 06:52 PM | #34 |
craftsman lathe 109 - Similar Threads | ||||
LR88/109 gmade sawback | wyetuck88 | G-Made Sawback | 14 | 03-08-2014 02:05 AM |
LR 109 Series & LR Discovery 3 Rc Expeditions | Radek | Videos! | 7 | 08-10-2010 12:30 PM |
scania 4 axle dual steering #109 | SEMIJOE | Non Crawler RC's | 3 | 11-25-2009 08:14 AM |
Airtronics 94359Z Servo for $109.99 | Azcats1 | Chit Chat | 9 | 01-14-2006 12:02 PM |
