04-18-2016, 03:40 PM | #1 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Got Myself a Cordless Driver
When I first got into into RC's, I started with inexpensive Integy hex drivers. They worked, but left a lot to be desired; they easily rounded off and the tips would snap. Then I after reading about MIP tools being the best, I sprung for the MIP 1.5, 2.0 & 2.5mm hex drivers. To date they still have sharp hex edges and work incredibly well, they insert into hex bolts perfectly and definitely prevent stripped hardware. I do lot's of bench wrenching and my wrists are starting to feel the pain after long sessions, so I thought I would treat myself to some new tools. I picked up a Milwaukee M12 Cordless 1/4" Hex Screwdriver Kit (2401-22). This comes with two batteries and a charger. I like the fact that the torque is adjustable, because I would rather use my MIP drivers to give the final torque by hand. Since I knew the MIP hand drivers were the superior tool, I ordered up a set of MIP Speed Tip Hex Driver Wrench Insert sets to use on the cordless driver. This tool fits the hand really nice, isn't heavy and is doing it's job perfectly as expected. There have been times that I have dreaded working on my RCs because of the large number of screws to get whatever particular job needed to be completed; i.e., maintenance. Now, I look forward to wrenching even more now that I can save my wrists from any additional discomfort. I should have done this much sooner! Last edited by bilinvic; 08-18-2017 at 11:03 PM. Reason: FU PB |
04-18-2016, 06:10 PM | #2 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Re: Got Myself a Cordless Driver
I thought about getting one, but doesn't it torque the nuts and bolts to tight and break them? __________________________ 1.9 Ibex tuber - The Merica ibex. |
04-18-2016, 06:16 PM | #3 |
Nice, Milwaukee and MIP tools have always been great for me too. I have a DeWalt 12 volt cordless drill and driver set that works great, but is a little bigger and heavier than this. Mine works great for RC and most around the house stuff, but yours looks better for compact, lightweight screw driving. DCK211S2 12V MAX* Cordless Li-Ion Drill/Driver / Impact Driver Combo Kit DCK211S2 12V MAX* Cordless Li-Ion Drill/Driver / Impact Driver Combo Kit | DEWALT Tools I'm going to check out the Milwaukee you linked, thanks! Last edited by Natedog; 04-18-2016 at 06:19 PM. |
04-18-2016, 06:17 PM | #4 | |||
| Re: Got Myself a Cordless Driver Quote:
04-18-2016, 06:25 PM | #5 |
RCC Addict Join Date: May 2009 Location: Weston
I have similar Ridgid and Makita versions of the same design except impacting and the MIP drivers. They are wrist and forearm savers! The most used tools I own. They work even better on the chassis screws in my Tekno stuff. They tend to stick and the impacting pops them right out. |
04-18-2016, 06:38 PM | #6 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
Nice make sure you get a 7mm nut driver bit also for quick tire changes.
04-18-2016, 06:41 PM | #7 |
| Re: Got Myself a Cordless Driver It would if you let it...that's why the torque is turned down low and final tightening is done by hand only. Like Natedog mentions, you cannot go full speed with the screws because the friction will melt plastic....and that's not a good thing.
04-18-2016, 06:42 PM | #8 |
| Re: Got Myself a Cordless Driver |
04-18-2016, 08:51 PM | #9 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
The day I picked up a 12v cordless drill for my rc's, was the best day ever. Makes life so much easier and like you said, helps with the wrists and makes you actually look forward to working on them. |
04-18-2016, 09:23 PM | #10 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
I love my 12v set !! I also just wanted to through out a little trick that I do.. I cut up a spare set of alen wrenches and use them in my drill.. Whenever they show the slightest wear I grind of a 1/16th ...new once again !! They last forever!!!
04-18-2016, 11:24 PM | #11 |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
Nice pick up! I'm having tool envy at the moment, as I've been wanting to start a cordless power tool system based on the Milwaukee 12v platform. I personally use a Ryobi TEK4 4.8v lithium ion driver which at the lowest setting will allow you to install switch plates without cracking them, and that is where I leave it for R/C nuts,bolts and screws, and I haven't stripped one yet even after being absent minded and letting a few drive all the way to the clutch release. Milwaukee also has a 4 volt system that probably would be better suited for a purely r/c or electronics assembly tool. |
04-19-2016, 11:15 AM | #12 |
Ryobi looks interesting too: 4V LITHIUM-ION SCREWDRIVER MODEL: #HP54L | HOME DEPOT SKU #: 1001059349 Battery: 4 Volt RPM: 200/600 (No Load Speed) Chuck Type: 1/4 in. Hex Tool Weight: 0.836 lbs https://www.ryobitools.com/power-too...ts/details/764 Milwaukee looks like better ergonomics and balance. |
04-19-2016, 11:20 AM | #13 |
I had that model in my hand, although it's probably decent for RCs, it really didn't compare to the Milwaukee. Plus I can use the Milwaukee for other jobs around the home.
04-19-2016, 01:05 PM | #14 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
This little guy has been my favorite. It is gyro activated; twist your wrist and it will spin that direction, the more you twist the faster it goes. I love it for the speed control. Been using it regularly with the MIPs drivers for over a year. So far, so good. http://www.amazon.com/Black-Decker-B.../dp/B008R5259Y Last edited by Chiphead; 04-19-2016 at 01:12 PM. |
04-19-2016, 03:34 PM | #15 | |
04-19-2016, 05:04 PM | #16 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
I have the DeWalt and love it! |
04-19-2016, 06:42 PM | #17 | |
04-19-2016, 08:42 PM | #18 |
I like my Craftsman with it's 24 position clutch. Sears.com If I need something bigger I have my drill. I don't want to hold a drill or impact when working on RC cars especially when trying to get in tight places. |
04-19-2016, 09:45 PM | #19 | |
04-20-2016, 06:19 AM | #20 | |
I did find a cheap replacement LiPo online at some point, but now I can't find it. If you open yours you may be able to get numbers off of it the battery that you can find online. I'm not sure if Craftsman sells replacements, but you should have contacted them about it dying after just a year. That is too short of a time. | |
Got Myself a Cordless Driver - Similar Threads | ||||
Cordless Driver - Adjustable Chuck Vs 1/4" Hex Chuck? | MailManX | Tools, and Procedures | 33 | 04-13-2014 03:03 AM |
mip hex driver or drill driver bits with racheting handle | 507Eli | Tools, and Procedures | 2 | 12-17-2011 05:07 PM |
