Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: magnetic table for tube work
Old 01-18-2017, 07:21 PM   #1
Default magnetic table for tube work
hay guys any one ever thought about using an electromagnet for holding tube work. was thinking it would be nice for the tube to stay in place while you have two hands to solder with. any ideas looking for pros and cons
thanks mike
dmgriff266 is offline   Reply With Quote
Old 01-19-2017, 08:02 AM   #2
No idea what I'm doing
Default Re: magnetic table for tube work
Sounds expensive. I use a plain steel plate with welding magnets, third hands and/or fixtures.
C*H*U*D is offline   Reply With Quote
Old 01-19-2017, 11:52 AM   #3
If I need an extra set of hands, or need to hold a tube at an angle, I use my welder to tack one tube to the table so I can hold the other tube to it without moving anything. Then I just use the dremel to cut it free.
makya is offline   Reply With Quote
Old 01-19-2017, 06:14 PM   #4
Instead of an electromagnet, look for a magnetic chuck for a surface grinder. They have permanent magnets inside and a lever that switches the magnet off and on.
HoosierClod is offline   Reply With Quote
Old 01-20-2017, 12:38 PM   #5
~THE SCALE SHOP~
from my experience with my TIG, welding doesnt like to be in a magnetic feild. whenever i get my magnets to close to the joint the arc goes nuts and i have trouble starting and concentrating the arc. never get a good weld.
move it away 1/2 to 1" and it works just fine.
STANG KILLA SS is offline   Reply With Quote
Old 01-20-2017, 05:03 PM   #6
^ what he said. My welder acts a bit crazy around strong magnets.
doubler is offline   Reply With Quote
Old 01-20-2017, 09:52 PM   #7
Suck it up!
Duuuuuuuude's Avatar
Also, heat kills magnets.
Duuuuuuuude is offline   Reply With Quote
Old 01-21-2017, 07:23 AM   #8
Heat doesn't kill magnets.
People with heat kill magnets.
Old 01-24-2017, 01:11 PM   #9
thanks for all the input. there are a lot of diferent ways to skin a deer. i guess its more what works best for your situation. i need two hands to solder or braze with. so i think i will try a magnetic table. going to have to try and build my own. again thanks for the input will post as build progesses
Old 01-31-2017, 03:16 PM   #10
Just go pick up a third hand. You can get all sorts of sizes that do fine for the tiny tube work we do. Super cheap too, so if you end up melting one up a bit, no biggy.
MiteyF is offline   Reply With Quote
magnetic table for tube work - Similar Threads
BoneheadRC’s CowRC Magnetic Work Mat Review! Team CowRC Non Crawler RC's 1 09-18-2012 12:58 PM
My work table! nitromtcrawler Chit Chat 5 03-06-2009 01:35 PM
