Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Alternative to Soldering
Old 07-17-2017, 09:09 AM   #21
Default Re: Alternative to Soldering
Have you thought about soldering outside? A fan blowing from behind you should take care of all the smoke.
jester_s1 is offline   Reply With Quote
Old 07-17-2017, 11:54 AM   #22
3m disposable respirator will last you 2-3 years if you seal it back up in the bag. I imagine you wont solder all that much to kill the respirator
CM9000 is offline   Reply With Quote
Old 07-17-2017, 01:54 PM   #23
Moderator
JatoTheRipper's Avatar
Good idea!
Doesn't mold grow from the moisture of your breath even in a sealed bag?
Old 07-17-2017, 03:25 PM   #24
A friend? Know someone who you trust, who will solder for your? Or, teach a wife, girlfriend, kid, etc. to solder, set the connections up the way you want them, and have them do the joining.
hodge5 is offline   Reply With Quote
Old 07-17-2017, 04:26 PM   #25
Originally Posted by JatoTheRipper View Post
Good idea!
Only if exposed to mold. My respirator is dried and wiped before I put it back in my storage bag . I suppose some use wipes for peace of mind.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-17-2017, 05:51 PM   #26
Do you still have a reaction if you use an inhaler *before* soldering? Oftentimes, allergic reactions are much easier to prevent with medicine beforehand rather than trying to subdue them after they start.
fyrstormer is offline   Reply With Quote
Old 07-23-2017, 09:46 AM   #27
Originally Posted by Waitwhatsthat? View Post
If you want to skip the solder, then try out some power pole connectors. You'll need the special crimper for them also. I used to use them before I became comfortable with soldering. They actually work really well. The only downside I had was on my short course truck they would sometimes melt due to the extremely high amp draw. On a crawler you don't need to worry about that. You can find them at most electronics stores, and usually cheaper than what an lhs might carry.
Sent from my XT1585 using Tapatalk
+1 for Anderson power poles and their crimper. I use them on all my batt packs. Only thing I need solder for is motor connections, but half the time they already have bullets on them anyway.
What's that: what size crimp pin were you using? Using the fattest ones ("45 amp") Even my 1/8th arrma running on 6s seems fine. ( and to folks new to app, note that the amp name doesn't denote their amp limit in rc application. It's more about how much current they can mange continuously over months/years)
AggressorBLUE is offline   Reply With Quote
Old 07-23-2017, 09:55 AM   #28
I was running the larger connectors. I could fit the 10awg battery wires on it. I did melt the connectors on my short course truck, but the system was way over worked. 4x4, 5250kv 2 pole motor and 120a esc. Running on 2s caused high current draw. It was really a poor setup for the truck. I was new though and didn't know any better at the time.
Waitwhatsthat? is offline   Reply With Quote
Old 07-23-2017, 10:12 AM   #29
Get yourself one of these.
https://www.amazon.com/Weller-WSA350.../dp/B000EM74SK
Tossedman is offline   Reply With Quote
Old 08-04-2017, 07:11 AM   #30
A respirator would be your best bet. Get a descent one as the cheap ones can get darn uncomfortable.
Rumpelhardt is offline   Reply With Quote
Old 09-29-2017, 09:44 PM   #31
McMaster-Carr sells a crimp connector with heat shrink and solder. The solder melts as you apply heat to shrink the insulation. No smoke!
Inspector86 is offline   Reply With Quote
Old 11-08-2017, 10:51 PM   #32
MODERATOR
THX_138's Avatar
No substitute for a good mask or respiratory system mask if you have breathing issues for any reasons.
THX_138 is offline   Reply With Quote
Alternative to Soldering - Similar Threads
An alternative to the Hobby King Yihua 936 Soldering station? DeoreDX Tools, and Procedures 13 02-05-2014 09:39 AM
alternative shocks lurch HPI Wheely King 5 04-24-2012 09:36 AM
Alternative to Spazstix mongoose Paint and Body 1 05-05-2011 02:36 PM
Burning through soldering tips? And other soldering questions losikid Electronics 14 12-16-2010 10:04 AM
What soldering iron for battery soldering? Flatty Electronics 1 06-23-2008 07:35 AM
