10-17-2017, 09:28 AM | #1 |
Pebble Pounder Join Date: May 2016 Location: Texas
| Lubricant
Hello all, I went to my local parts store and bought the grease below, to lubricate my differentials, and drive shaft slip yokes, and so on. I don't see why it wouldn't work, but I just wanted to get the opinion of others. Any help or insight you can give me would be greatly appreciated. |
10-17-2017, 04:05 PM | #2 |
| Re: Lubricant
I use red and tacky for the diffs and just a light coating on the trans gears. I usually dont lube the slip joints on my driveshafts as that just attracts dirt...
10-18-2017, 03:24 PM | #3 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| Re: Lubricant
+1 ^ . I use red and tacky as well. Sticks great to the gearing and doesn't fling off easily
10-18-2017, 04:22 PM | #4 |
| Re: Lubricant |
10-19-2017, 05:52 AM | #5 |
| Re: Lubricant
This is one instance where searching would have yielded tons of results. That is if you use Google to search this site. Grease / lubricants have been discussed at length on this site. Here are two of the better threads: Gear Grease... Let's talk grease! |
10-19-2017, 07:20 AM | #6 | |
| Re: Lubricant Quote:
10-19-2017, 07:28 AM | #7 |
| Re: Lubricant |
10-26-2017, 01:37 PM | #8 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| Re: Lubricant
This is what I'm using as my "go to" lube so far. Plastic on Plastic- TrakPower Krytech Ring and Pinion- Going to test both Krytech in front diff and White lightning Clean Ride in rear diff to see how long they last. Might end up using Tamiya Anti-Wear grease if results are poor. CVD joints- Krytech...I've found RC4WD shock boots work great to prevent dirt from entering CVD. Axle housing to prevent water intrusion- Bel-Ray Waterproof Grease. If your looking for an all around grease I would suggest Super-Lube. Safe for almost all plastic and nice to have around the house. Last edited by MAGNUMB; 10-26-2017 at 01:41 PM. |
11-07-2017, 11:18 AM | #9 | |
Newbie Join Date: Sep 2017 Location: cincinnati
12-08-2017, 06:51 AM | #10 |
Quarry Creeper Join Date: Aug 2017 Location: KY
| Re: Lubricant
I use Bel-Ray waterproof grease in our diffs and trans. I’ve used it for years on motorcycles (dirt & street) and never been disappointed. https://www.amazon.com/gp/aw/d/B0045...TyL&ref=plSrch |
12-14-2017, 07:59 PM | #11 |
| Re: Lubricant
I use Phil Wood bicycle grease. Waterproof, good viscocity and plenty durable for trans and diff gears. Agree with others, I would definitely not grease anything on the driveshafts. At most, use a silicone spray and then thoroughly wipe them down to remove the excess.
Lubricant - Similar Threads | ||||
Lubricant for metal spur/pinion? | theTman | General Crawlers | 16 | 02-02-2017 07:03 PM |
Dry film lubricant | adamsfly | Newbie General | 4 | 02-19-2012 05:39 PM |
Freeze proof lubricant? | Gregorius | Axial SCX-10 | 4 | 02-05-2011 06:29 PM |
Lubricant for links/etc | rerock | General Crawlers | 4 | 04-21-2006 10:40 AM |
