11-09-2017, 12:47 PM | #1 |
Newbie Join Date: Apr 2017 Location: usa
| soldering lipos
is there any danger involved in soldering connectors on lipo batteries? i want put new connectors on some 300mah/2s/7.4v lipo batts for my micro.also dont know which soldering iron[temp range]to use!-help.
11-09-2017, 01:05 PM | #2 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: soldering lipos Quote:
Sent from my SM-N900T using Tapatalk | |
11-10-2017, 07:12 AM | #3 |
Newbie Join Date: Jul 2017 Location: Atlanta
| Re: soldering lipos
Just don't clip both the pos and neg at the same time. If you do it will make a nice spark and leave a permanent indentation in your wire clippers. Don't ask me how I know this! No other dangers really. Just complete one wire at a time. Cut, strip, tin, put heat shrink on wire, solder to connector, heat gun the heat shrink, THEN move on to the next wire. Don't know about temps... My 20 year old Weller isn't adjustable, but has always seemed *just right*. Great soldering info here (if you have a spare hour): https://www.youtube.com/watch?v=KPbozW0Y3p4 |
11-11-2017, 11:06 AM | #4 |
| Re: soldering lipos
someone soldered the original connector on, no reason you cant put the style you want on.
11-21-2017, 10:11 AM | #5 |
Rock Crawler Join Date: May 2016 Location: SoWIs
| Re: soldering lipos
Actually there is, particularly if the battery is "full" and a smaller physical size. Excessive heat can damage the battery (150F+, solder melts >425F) and it's more dangerous with a charge in it. You should use at least a 60W or 100W soldering iron and heat the tab thru the wire. By that I mean heat the wire then press it to the tab til the tab melts. That reduces heat. Also if the tab isn't pre-tinned you'll need special nickel-compatible solder. Make sure you do it near 2 buckets of sand/dirt or outside. Water won't put out a lipo fire, only burying it in sand/dirt will. After it's done make sure you wrap the 2 leads in kapton tape, although elec tape will work too. It's best to use masking tape when soldering since it doesn't melt like elec tape. |
11-22-2017, 11:03 PM | #6 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
11-23-2017, 03:00 AM | #7 | |
Pebble Pounder Join Date: May 2016 Location: France
Now I do it one wire at a the time, with the other one taped to lipo so it stays there | |
01-01-2018, 03:39 AM | #8 | |
Pebble Pounder Join Date: Nov 2014 Location: Camby
soldering lipos - Similar Threads | ||||
Compare the Zippy Compact Lipos to a few other lipos... | Mdlopez1 | Electronics | 15 | 07-15-2013 06:35 PM |
Soldering Deans On Lipos | WestTxRc | Electronics | 27 | 10-13-2011 11:15 PM |
Burning through soldering tips? And other soldering questions | losikid | Electronics | 14 | 12-16-2010 10:04 AM |
New on Lipos, how to no waste money in overpowered LIPOS. | raolguio | Electronics | 6 | 11-03-2010 03:08 PM |
What soldering iron for battery soldering? | Flatty | Electronics | 1 | 06-23-2008 07:35 AM |
