11-11-2017, 12:21 PM | #1 |
| Pefect Shock Oil Volume
I was sick of just "eye-balling" my shock oil level when building and refreshing my shocks. Seems like I would always have to add a bit more, pour some out, to even them up, then the shock bodies would get oily and slick. I went to my local drugstore and got a medicine / irrigation syringe. Works perfect and measurable down to the cc. Simply stick it in the shock oil bottle, draw the plunger up to exactly what you need, then squirt it into the shock. |
11-14-2017, 07:26 PM | #2 |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
| Re: Pefect Shock Oil Volume
Recently started educating myself with shock oil, and its effects(wt) and proper amounts etc. Very simple stuff, not a lot to it, but to be able to accurately measure the CCs or whatever measurement for all 4 shocks is pretty sweet! Great idea and cant wait to add a small syringe to my collection of useful tools. |
01-06-2018, 01:00 AM | #3 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
What a good idea. Thank you so much for the tips |
01-06-2018, 01:41 PM | #4 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I use little syringes like that for: Shock oil Oil Waterproof Grease Dielectric grease Shoe goo (syringes are single use in this case) Other stuff that I can't think at the moment.. They're super handy, best thing to come from having a sick animal was acquiring a supply of those.. |
02-09-2018, 07:14 AM | #5 |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
SWEET idea!! I should have read this BEFORE building my Shocks. I did get other helpful tips though... My Wraith Kit came with Icon Aluminum Shocks. After hearing from the Naysayer Gallery, telling me how bad they're going to leak, I got some actual help! A thin 3mm shim added to the lower seals, compresses the O-Rings just enough to seal better. That, and use lots of Green Slime! So I was generous with the Green Slime, and added Shims...... Almost Two Weeks, sitting on the Stand, and not even slightly damp seepage!!! That means they'll hold up pretty well when I actually RUN her!! Seriously, I've got a few of those irrigation syringes, plus about 1000 100cc syringes for my Insulin. Maybe I can find a better use for them, besides torturing myself! Great idea Mike, and thanks for sharing it! |
03-14-2018, 06:42 PM | #6 | |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
| Re: Pefect Shock Oil Volume Quote:
03-15-2018, 12:36 PM | #7 |
Newbie Join Date: Feb 2017 Location: Seattle, WA
Yep, syringes are great for this stuff. I go to farm supply stores to get mine. Larger size selection, cheaper prices. I also use blunt tip needles as well for precise application of glues and such. |
Pefect Shock Oil Volume - Similar Threads | ||||
motor oil as a shock oil? | Mr.JayDeeM | General Crawlers | 10 | 09-02-2012 10:59 PM |
shock oil | Ruggalo | Newbie General | 2 | 07-05-2012 08:36 PM |
Shock oil and shock spring help | entropy | General Crawlers | 10 | 01-29-2011 08:40 AM |
best shock oil and gear oil | j4k3 | Axial SCX-10 | 2 | 07-26-2010 12:48 PM |
help! What shock oil do I need? | thetoptanner | Axial AX-10 Scorpion | 7 | 07-11-2008 07:34 AM |
