08-04-2017, 05:44 PM | #1 |
Pebble Pounder Join Date: Mar 2015 Location: PEI Canada
| small tap set
hey guys, i'm looking for a tap set to work with the small 2.5mm screws we use. Also what size do I need to look for? I have a normal tap and die set, but its to big. thank you |
08-04-2017, 07:06 PM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: small tap set
I'm not quite needing it yet, but I've looked at them on ebay under "Mini Tap and Die Wrench Set M2.5 Set". You'll also need to look under "2mm drill set" for the bit needed for that hole. If you get set that works for you, let me know. |
08-04-2017, 08:02 PM | #3 |
Quarry Creeper Join Date: Oct 2014 Location: East
| Re: small tap set
I bought these sets a few years ago. They saved me last year at ECSC. The grub screw ripped out of my winch. I re-drilled for 4mm and threaded it. I was back on course in less than a 1/2 hour. Not cheap but has all the sizes you'll need. You can get them at Tower. TowerHobbies.com | Dubro Tap & Drill Set Metric (10) |
08-04-2017, 10:36 PM | #4 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
| Re: small tap set Quote:
One more thing, I usually like to have at least two (2) of each size on hand as these small size taps tend to break at the most inopportune time (Friday evening when rushing to finish up a project for the next day crawling/trailing outing). | |
08-05-2017, 10:35 AM | #5 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
| Re: small tap set
Great Planes makes one just like the Dubro pic'd above, part# GPMR8118 for the metric. |
08-05-2017, 01:24 PM | #6 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: small tap set
I would just buy the single sets through dubro. You only need a few of the popular sizes.
08-06-2017, 05:16 AM | #7 | |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
If you will be tapping anything thicker than 1/8", be sure to go easy and oil up. Nothing worse than snapping a bit off on your last hole, while being over zealous to finish. Be sure to purchase a good quality "T" wrench that fits your bit properly. | |
08-06-2017, 10:15 AM | #8 |
| Re: small tap set
Hey guys I found these on amazon. https://www.amazon.ca/gp/product/B00...9QUE9EAD&psc=1 https://www.amazon.ca/Cutting-Diamet...A3N7N698MZC9Q9 Do you think they would work? |
08-06-2017, 08:00 PM | #9 |
| Re: small tap set
Micromark.com is a great place to find miniature tools and supplies. |
08-06-2017, 11:27 PM | #10 | |
Spend a little more for quality, about $4 to $7 Canadian EACH for something that won't leave you frustrated with the results. | |
08-07-2017, 06:51 AM | #11 | |
McMaster-Carr is a good place to look for stuff like taps. Do you have an industrial supply house like McMaster in Canada? | |
12-12-2017, 10:31 AM | #12 |
Newbie Join Date: Aug 2017 Location: MCMINNVILLE
| Re: small tap set
Little Machine shop----has small taps and other useful stuff https://littlemachineshop.com/produc...ory=-187829314 |
12-12-2017, 10:58 AM | #13 |
| Re: small tap set
If you aren't, I would do some some reading up on various tap types. I went years using the lamo du-bro 3mm taps for rc work. Little did I know I was using the wrong type and kept breaking taps. Get some good quality "Through Hole" or "Blind Hole" (If needed) taps.
12-13-2017, 12:43 PM | #14 | |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
On to taps. I bought a cheap metric tap set at Banggood. I bought it specifically for the M3 tap, but so far it's doing ok. Since I'm mostly just tapping plastic and maybe some aluminum, the cheap set was all I needed. | |
12-13-2017, 02:40 PM | #15 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
| Re: small tap set
I've had good luck with MASTER MECHANIC brand
small tap set - Similar Threads | ||||
metric tap and die set- where to buy? | LoneRanger | Tools, and Procedures | 16 | 03-29-2014 05:05 PM |
decent to good tap and die set??? | donhd04 | Tools, and Procedures | 23 | 07-05-2012 12:54 AM |
Suggestions for a Tap and Die set | TJ_Shunk | Tools, and Procedures | 16 | 02-25-2010 08:37 PM |
Tap and Die set... | Synister_Intent | Tools, and Procedures | 12 | 11-06-2009 09:34 AM |
looking for a screw tap set | muddeprived | Tools, and Procedures | 13 | 01-06-2009 07:23 AM |
