04-23-2018, 05:33 PM | #381 |
| Re: 3d printer for rc parts
JRH hit it, the tall prints, and fast speed create a shake in the frame, the braces eliminate it. I put them on mine as it seems steadier, and I was able to get everything square. Hang up and Drive |
04-23-2018, 10:09 PM | #382 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
Still working on dialing in and repairing this "refurbished" printer, but got my first functional (non-cosmetic) RC parts off it this evening. Have a nice set of old Vanquish SLW wheels I got in a trade, but they're too narrow for my tastes. Tires looked really sucked-in. No one seems to make spacers for these anymore so I made my own.... Sent from my SM-G930V using Tapatalk |
04-24-2018, 06:47 PM | #383 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
Made my 1st R/C part that I designed myself with Oneshape. It's a 1/35th scale stand for my Orlandoo's Last edited by Gramps; 04-24-2018 at 06:53 PM. |
04-25-2018, 10:36 AM | #384 |
RCC Addict Join Date: May 2015 Location: Price Twp.
Anyone printing with flexible filament? I am going to attempt to make some drive belts up. Looks like the CR-10 requires a few simple mods to work.
04-25-2018, 11:14 AM | #385 |
Rock Crawler Join Date: Nov 2014 Location: Dells
@gramps enable ironing, it smooths out all of the top surfaces and looks worlds better on most prints |
04-25-2018, 11:39 AM | #386 |
| Re: 3d printer for rc parts |
04-25-2018, 11:49 AM | #387 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
I believe Cura has the option Sent from my Nexus 5 using Tapatalk |
04-25-2018, 11:50 AM | #388 |
04-25-2018, 01:31 PM | #389 |
| Re: 3d printer for rc parts [QUOTE=MasteroFlego;5825595]I believe Cura has the option I embarrassed then . I’ve never heard of it, use 3.2 daily, great results. What area are the settings in ? Experimental ? Is this for single extruders or double ? Hang up and Drive |
04-25-2018, 02:12 PM | #390 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
I don't believe Slic3r has the option, yet.
04-25-2018, 02:45 PM | #391 |
[QUOTE=mikemcE;5825636]Pref, configure, search "iron" It's under the shell section
04-25-2018, 02:55 PM | #392 |
Is there an easy way to splitup an STL? https://www.thingiverse.com/thing:2788903 The mount part of this won't fit on my bed, but I could print out the parts individually diagonally |
04-25-2018, 04:14 PM | #393 |
Well well well! Went to check it today, and found Cura 3.3 is out. So upgraded to that. Big difference is no more automatic slicing. I had already disabled that, but looks like some freshness. I did find ironing, and a 20 x20 x20 cube is printing now and being ironed.... I will see! Thanks for the heads up ! Hang up and Drive |
04-25-2018, 06:36 PM | #394 | |
| Re: 3d printer for rc parts Quote:
Sent from my Nexus 5 using Tapatalk | |
04-25-2018, 06:59 PM | #395 |
Won’t that make meshes from drawings ? Not sure it does cut, that would be a great addition Hang up and Drive |
04-25-2018, 07:00 PM | #396 | |
04-25-2018, 07:35 PM | #397 | |
The extruder speed and temperature really dialed in to prevent getting a extruder jam. If you push it too fast, it compresses which shortens it length but increases the diameter which then causes a jam. The idler being too tight can cause it to bunch up too and not go down into the hot end. Nothing like finding filament coming out the side of the extruder. If the distance between the hob bolt and the filament guide is too wide, then the flex filament can squish out the sides too. This one of the things that the mods to the extruder tries to address. Once you get the printer dialed in, printing with flex comes out really well. This is one of the web articles that I used when I was first starting out with flex: https://www.matterhackers.com/news/h...xible-filament | |
04-25-2018, 07:42 PM | #398 | |
SCX10 Rack Split | |
04-25-2018, 07:48 PM | #399 | |
Does lowing the print speed help at all? Thanks | |
04-25-2018, 07:55 PM | #400 |
Looks like Repetier Host has an object split function as well. Seemed to work when I tried it. The zip I posted was split with Meshmixer.
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
