08-12-2018, 12:08 PM | #721 | |
Rock Crawler Join Date: Mar 2016 Location: Murphy
| Re: 3d printer for rc parts Quote:
MIght try a raft later and see what happens. | |
08-12-2018, 12:42 PM | #722 |
Rock Stacker Join Date: Oct 2014 Location: Raeford
Another thing to try with the brim is instead of brim being say 1.5mm,2mm or so from part. Set that to zero, it acts kind of like a raft, but is easier to remove and doesn't seem to affect the outcome as much
08-12-2018, 03:38 PM | #723 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Try printing with supports? Print it laying down too. |
08-13-2018, 05:32 AM | #724 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
Your brim should connect to the print already. If it does not connect then it is a skirt. You really shouldn't have to make that adjustment, the few slicers I have used differentiate between the two settings. | |
08-13-2018, 10:21 AM | #725 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: 3d printer for rc parts PLA for now. I imagine I will ultimately have to go with something stronger but going to give this a go for now. Bumped the heat up just a bit for better adhesion and printed w/ 2mm walls/ceiling/floor and 30% infill.... We'll see how strong it is... Hope to be able to work on it a bit tonight, been busy buying/selling/working on my 1:1's for the last week or so, lol |
08-13-2018, 07:43 PM | #726 |
Still very much a work in progress... had to improvise some upper-rear links for now... Sent from my SM-G930V using Tapatalk |
08-13-2018, 08:04 PM | #727 |
The brim does connect to the part
08-17-2018, 07:34 AM | #728 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Raspberry Pi, Have Octopi loaded and Pi camera working. Now to get it to talk to my printer . |
08-17-2018, 10:10 AM | #729 |
| Re: 3d printer for rc parts |
08-17-2018, 10:47 AM | #730 |
08-17-2018, 12:08 PM | #731 |
It took me longer to find a power pack than to setup octopi.... Copy/extract OS files, edit txt filr with wireless info, done |
08-17-2018, 12:55 PM | #732 |
08-17-2018, 09:51 PM | #733 | |
I use this interface to upload my gcode to Optopi and then send it to the printer. I can then use my browser or my phone to check on the progress. I don't have mine setup to montior it on other than the local network. | |
08-18-2018, 05:45 PM | #734 |
Rock Crawler Join Date: May 2018 Location: USA
So I was really impressed with my Vader skid plate made out of Delrin. So I looked into it as I thought it was a thermoplastic, and it was! Here is the link: https://gizmodorks.com/acetal-3d-printer-filament/ Im gonna get some and give it a try, but if we can get it close to the same quality as injection molded Delrin this stuff could be the holy grail of load bearing parts! Stats show it as even better than HIPS! |
08-18-2018, 07:24 PM | #735 | |
Been there, done that... Still have 3/4 of the 200g roll Good luck getting it to stick and not peal off after a couple layers. The only thing I haven't been able to try is with the bed at 150c+ like some have reported success with because of firmware issues. Glass, glue, contstruction paper, super98 spray adhesive, etc, nothing worked. | |
08-18-2018, 08:29 PM | #736 | |
08-22-2018, 01:54 PM | #737 |
Mine does great for my (hobby) purposes and is simple to operate. I have an A8, and it's definitely not a turn key proposition but if your handy and willing to spend some time to get to know it its a great entry level printer. |
08-22-2018, 04:40 PM | #738 |
Maker Select V2 here. Decent prints after mods/tuning, but also requires learning the machine and fixing your own issues. I think all budget-friendly machines are going to have similar learning curves... Sent from my SM-G930V using Tapatalk |
08-22-2018, 07:18 PM | #739 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I have the Maker Select, and I tgought it was very noob friendly. I went from nox to printing in a half hour, and the default Cura settings were good enough to get started. There were some upgrades worth doing, but I printed most of them out for my first prints.
08-22-2018, 08:41 PM | #740 |
I started several months ago with a PowerSpec Duplicator i3 Plus (rebranded Wanhao) like others said there was and still is a learning curve. I was printing the sample files within 45 minutes of unboxing it. I then printed using the Cura that it came with. After a few prints with that I expanded out and looked at other slicers, one reason was I use Linux. I to printed a few mods for it.
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
