11-05-2019, 01:37 PM | #1001 |
Quarry Creeper Join Date: Nov 2018 Location: 🌎
| Re: 3d printer for rc parts
Here are some beadlock wheels I am printing right now on the Ender 3. Total cost per three piece beadlock wheel is $0.75, for a total of $3 for a set of 4 wheels. Not bad! Last edited by Stomp; 11-05-2019 at 01:43 PM. |
11-11-2019, 02:01 PM | #1002 |
Question for the mechanical side of the printers. I want to/have to replace the V-Wheels on my Ender3 but noticing Polycarb ones now available. Was intending on ordering the Delrin, POM as the fancy want to call it, ones but noticed there's Polycarbonate ones available now. Opinions between the two? Thanks |
11-18-2019, 05:02 AM | #1003 |
Rock Stacker Join Date: Mar 2012 Location: ohio
Is there any consumables that these printers need? After buying one what all would you need to use one?
11-18-2019, 05:20 AM | #1004 | |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: 3d printer for rc parts Quote:
Over time you'll need lubricant (oil/graphite) and eventually bearings and other replacement parts but that's to be expected with anything mechanical. | |
12-08-2019, 05:45 PM | #1005 |
Pebble Pounder Join Date: Aug 2010 Location: Anderson, SC
I’m not sure if this is the right place to post but I use a Modified Monoprice Maker Plus (Wanhao i3Plus). I typically use PLA+ filament because it is easy to use and prints so nicely. The problem is over time I feel like parts become brittle. I have a heated bed and Micro Swiss hotend but no enclosure. I like printing pretty elaborate RC parts. Like transmissions, shock towers, etc that require decent tolerant and fitment. My question is what filaments have you used with a similar printer with success? Sent from my iPhone using Tapatalk Last edited by gsgraber92; 12-08-2019 at 05:47 PM. |
12-08-2019, 07:27 PM | #1006 |
I print PETG all day long on my III plus. Same settings as PLA, but Hot end is 240c Bed 80c. I also run the micro Swiss, and did the mosfet mod. I printed this wraith skid in PLA, then switched it over to PETG, must have done a dozen of them for buddies Hang up and Drive |
12-09-2019, 05:59 AM | #1007 |
If you don’t mind me asking, what brand of PETG do you like to use? I have used it but it but it doesn’t seem as clean at PLA. I would like to try it again. Sent from my iPhone using Tapatalk |
12-09-2019, 07:50 AM | #1008 | |
https://www.amazon.com/gp/product/B01KWVOFD4 Last edited by punkindrublik; 12-09-2019 at 07:55 AM. | |
12-09-2019, 09:00 AM | #1009 | |
Started with Monoprice, works well, I’ve printed gray, red, black, and white, all worked the same, currently printing red cones now. Did set up a fine .016 profile works ok, still a few infill tweaks needed. I bought some TPU, and want to try cones in that Hang up and Drive | |
12-09-2019, 09:01 AM | #1010 | |
Just bought a spool of that, looks like fun Hang up and Drive | |
12-09-2019, 01:22 PM | #1011 |
I use Tha Amazon black petg. I think the black filaments tend to string more. I upgraded my anet a8 to a knock off e3d v6 hotend and bowden tube and the stringing went away almost completely. Which was pretty unexpected really. Bowden tubes usually make the stringing worse. If there is a gap in the the hotend at the base of the pft sleeve molten filament pools and makes retraction more problematic. An almetal hotend may fix that. I don't have one though. Sent from my SM-N950U using Tapatalk |
12-22-2019, 09:13 PM | #1012 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
| Re: 3d printer for rc parts |
12-24-2019, 10:16 AM | #1013 |
Pebble Pounder Join Date: Sep 2018 Location: Canada
12-24-2019, 01:38 PM | #1014 |
12-24-2019, 05:22 PM | #1015 |
12-24-2019, 09:39 PM | #1016 | |
Buy white, Tamiya sprays work well. I seem to use more white on serious jobs, the colored ones I buy are for practice /test prints as they are cheap, and usually metallic and sparkly. Test temp and diameter on all new filaments as SOP Hang up and Drive | |
01-01-2020, 07:05 PM | #1017 |
New printer, New filament for a new decade. CR20 Pro, ProtoPasta HTPLA Prints like a dream, with The latest version of Cura(4.4?) If you use a Creality Profile, it will have “dynamic “ layer(.16) and (.20) normal, the quality the dynamic layer is phenomenal! In a nutshell, it’s the “Creawesum” mod from before, and it works well.noticeably smoother on all printers, by looking at the profiles. My older time learned and tweaked profile is almost a mirror of this OOB profile!!! Wow! Hang up and Drive |
01-02-2020, 07:29 AM | #1018 | |
I printed the VS4-10 inner fender brace. The base, on my build plate, prints perfectly. Then it starts doing this as it moves up to the top. What is causing this and how do I fix it? | |
01-02-2020, 07:51 AM | #1019 |
Print it gussets down, rotate 90. My new printer is an Creality CR20 Pro I grabbed it for 299. At AMain. 24v power supply, auto leveling, a bit smaller than the CR10, and bigger than the 3 all metal, solid and quieter than my III plus. I did print a wad of those, different infill, for heat treatment. Last night I did my old standby the Benchy, in dynamic mode. One minor bridging flaw in the arch. I will post some pix up when home. Hang up and Drive |
01-02-2020, 08:27 AM | #1020 | |
Black Friday steal I assume? | |
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
