12-14-2017, 10:44 AM | #1 |
Newbie Join Date: Oct 2017 Location: Lowell
| Small Tools Tool Kit
Are there any "kits" for assembly/maintenance tools? Seeing everything is so small might be hard to find everything a piece at a time
12-14-2017, 11:24 AM | #2 |
| Re: Small Tools Tool Kit
You don't need many tools to have a complete assembly kit. Some good regular and Phillips screwdrivers, 1.5mm, 2.0mm, 2.5mm, and 3.0mm Allen/hex drivers and 5mm to 8mm sockets or nut drivers. I was going to link you to the MIP driver set on Tower and it's MIA. MIP is just gone from Tower completely. The Duratrax are just as good: https://www.towerhobbies.com/cgi-bin...?&I=LXFAK6&P=7 I have the Duratrax nut driver set, but I can't find those either. Something is going on with HobbiCo. |
12-14-2017, 12:17 PM | #3 |
In addition to the wrenches mentioned, a 5.5mm open ended wrench has been the best addition to my tool set. On most of my trucks, it seems 75% of the 3mm nuts are in a location that you can't access with a nut driver. I use the open ended wrench way more than I use an actual nut driver. https://www.lowes.com/pd/Kobalt-5-5-...IaAhUKEALw_wcB |
12-14-2017, 02:59 PM | #4 |
Rock Crawler Join Date: Apr 2014 Location: Portland
| Re: Small Tools Tool Kit |
12-15-2017, 04:03 AM | #5 | |
| Re: Small Tools Tool Kit Quote:
12-15-2017, 05:01 AM | #6 | |
| Re: Small Tools Tool Kit Quote: Yeah I'm not sure what's going on. | |
12-15-2017, 08:02 AM | #7 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Small Tools Tool Kit Quote: Spend a little more and get a good set of hex wrenches. They will last forever and the time and frustration that you save by not constantly stripping screws is worth it. MIP tools are top notch. The higher end (more expensive) Duratrax tools are good. I regularly use a set of the red aluminum handled Dynamite drivers and they are good, but I prefer the MIPs. | |
12-18-2017, 01:46 AM | #8 |
RCC Addict Join Date: Nov 2010 Location: England
5.5mm combination wrench. Small long nose pliers. Pointed tool like a scriber for helping line up holes. Plus the stuff in posts above.
12-23-2017, 08:06 PM | #9 |
Newbie Join Date: Oct 2017 Location: SF Bay Area
I bought that Dynamite Startup Tool set to build my first kit, an SCX10.2. It’s just fine but the drivers are clearly going to wear out pretty quickly. Have been slowly adding MIP for the most frequently used tools and WOW they are a whole different animal: really good stuff. Manufacturing wise it’s like the difference between a Wal-Mart laptop and a MacBook Pro.
12-30-2017, 06:57 AM | #10 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
I was so happy about my LOSI 4 in 1 kit, so after 10 years and a couple of them finally broke ( misuse ) then i just had to get another set. Couldn't find LOSI so went with another brand but similar product it would seem. https://www.modelsport.co.uk/fastrax...products/28766 And then to be on the safe side i got 4 individual metric hex drivers from EDS but with a 120 mm long tip, cuz even with the little cars some times you need a little extra reach. The 4 in 1 fastrax kit are in my spare parts assortment in my backpack, along with a T key for nuts and a little long nosed pliers, and other bits and bops for on the trail repairs. |
01-06-2018, 03:49 PM | #11 |
Newbie Join Date: Jan 2014 Location: DFW
I am getting ready to order some more MIP drivers after a few cheap hex drivers died during my SCX build. Maybe a dumb question, but is there any reason to stock up on standard (SAE) nut drivers/hex wrenches, or do all crawlers use metric sizes exclusively? (I notice one of the posts above mentions SAE).
01-06-2018, 03:56 PM | #12 |
MOST only use Metric. Losi uses SAE so if you buy a Nightcrawler you'll need them. Also for some reason Vanquish uses SAE for their wheels.
Small Tools Tool Kit - Similar Threads | ||||
My RC tool kit. | Pete9 | Tools, and Procedures | 11 | 02-26-2017 03:05 PM |
Which tools required to assemble kit? | jeffncs | Tools, and Procedures | 6 | 12-29-2013 09:18 PM |
what tools are needed to build the kit | Empire932 | Axial AX-10 Scorpion | 8 | 07-21-2009 12:01 PM |
