12-29-2017, 10:59 AM | #21 | |
Rock Stacker Join Date: Jan 2009 Location: Carthage
| Re: Got a 3D printer on the way, got a design question Quote:
12-29-2017, 11:11 AM | #22 | ||
Learn Fusion 360 in 60 Minutes https://www.youtube.com/channel/UCiM...bW5mbx0iDcRQ2g | ||
12-29-2017, 11:14 AM | #23 |
Awesome thank you sir.
12-29-2017, 11:34 AM | #24 | |
Autocad didnt verify anything ...... | |
12-29-2017, 02:50 PM | #25 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Solidworks doesn't require much anymore for the student versions....you can get them direct off amazon now for $100 or so....but they expire in 2 years and they do have limitations....along with using it for commercial purposes is a big no no and they do go after people for it....and they do catch people. Get fusion and be done with it...its free, no drama....and you can pull yer models up on any computer its installed on....and it does cam if you need it. Later EddieO |
12-29-2017, 05:50 PM | #26 | |
I've tried a few times to use Fusion 360, I can't get a feel for it. I hate having to key in commands to make basic functions work, even though making keyboard shortcuts in SW isn't much different fundamentally. If you're a veteran, Systems Desault will give you a full blown version of SW for a very minimal dollar amount. You have to deal with them directly, not a software re-seller. | |
12-29-2017, 06:36 PM | #27 | ||
Fusion is the same thing for me, it feels weird and I cant wrap my brain on it yet. Autocad is just user friendly for me. I learn by doing so to watch videos and try to learn that way is harder then trying to figure out machine settings for cutting anything besides carbon fiber lol. Math is easy in my head but google is great when Im trying to figure out settings to cut metals. | ||
12-29-2017, 10:33 PM | #28 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I'm definitely having a hard time getting over the Fusion learning curve. I was able to bang out a somewhat simple shape (LED light bar mount), but then when I had to go back and move a couple holes, it was quite apparent that my sledgehammer approach wasn't going to cut it, so I had to more or less start over, and over, and over, and... until I finally had it done in a way that allowed me to move things after the fact. Then I had to get cocky and put an arched screw slot into it to let the light bar pivot. I ended up spending almost all day modifying a simple design until I got it how I wanted it. It gets easier with every screw up though! |
12-29-2017, 11:45 PM | #29 | |
12-30-2017, 01:51 PM | #30 | |
There's no right or wrong design software per say, if you're competent/comfortable in a certain one then it's probably the right one for you. | |
12-30-2017, 04:48 PM | #31 |
Newbie Join Date: Dec 2017 Location: Cincinnati
With Fusion 360 you can set it to back up to your own drop box and one drive account, I recommend Fusion 360 because it is free for hobbiest /small businesses until you make $100,000 with it then you are supposed to pay for it .
Last edited by JM-RC; 12-30-2017 at 04:48 PM. Reason: because I suck at grammatical accuracy |
12-31-2017, 09:27 AM | #32 |
| Re: Got a 3D printer on the way, got a design question |
12-31-2017, 10:02 AM | #33 |
some information worth passing on: use Fusion for the following reasons :
The place I'd invest money is into brand of material and the slicing program Simplify3d is absolutely unmatched in the Quality . I have used Cura and MatterControl. Both are subpar and super buggy but yes they are free. Simplify is around $100 for a lifetime livense but the cost definitly shows you get what you pay for . |
01-14-2018, 09:55 PM | #34 |
Rock Stacker Join Date: Oct 2014 Location: Raeford
Just saw this cloud based one that seems pretty good www.vectary.com |
01-15-2018, 04:01 AM | #35 |
Pebble Pounder Join Date: Jan 2018 Location: Spain
I use Onshape for the hobby and work, and I think that at the moment it is the most advanced 3D CAD you can find. It is very easy to use, fully capable to any mechanical engineering design task, and more with the available third party apps. Works on any computer as it is web/cloud based. It has been created by the exCEO and exCTO and part of the team of Solidworks so they know what a 3DCAD software needs. Been using it for the last 3 years. And the best, is that is free for hobbyist, there is no software capabilities reduced on the free version, only limited cloud space. Here is the link: www.Onshape.com |
01-15-2018, 04:24 AM | #36 |
Pebble Pounder Join Date: Feb 2012 Location: UK
| Re: Got a 3D printer on the way, got a design question What kind resin would you recommend in order to make some quality, resilient and durable suspension arms?
01-15-2018, 12:08 PM | #37 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
As a mechanical engineering tech, I'm also a daily "professional" user of Solidworks for solid modeling. I also use MasterCAM for all of our programming needs. Similar to many here I tried Fusion360 and hated it. I'm so adjusted to SW that I actually found it unusable and gave up on it pretty quickly. I'm using Onshape and I really like it. The UI is so similar to SW that the transition between them is essentially seamless. I don't love that anything I create with it becomes public domain, but that's the price I pay in order to use the service for free. The only thing I don't like is the lack of a small business/artisan license option. I would like to upgrade to a service level that allows me to privatize/protect my files but I can't justify the $1500USD/year cost right now. |
02-07-2018, 06:49 AM | #38 |
Newbie Join Date: Mar 2016 Location: Cincy
Look into OnShape. It's free and is similar to Solidworks. I've been using SW for the past 10 years as well and for home use to import/export STL files and even create decent manufacturing prints it works. My daily job is a Design Engineer for tooling/gauges in a production facility. As far as 3D printing and design engineering...yes fillet everything. Not only does it create a more finished look but it's also functional. Pay attention to wall thickness as well. I run a $100,000 machine here at work (Stratasys Eden 260V) which prints using a "jetted" process. This gives very good printing resolution and surface finish. Things to consider: Printer process: jetted, SLA, FDM (FDM is for compression loads only IMO, but not shear loads. Jetted can handle both) Printing material Intended part use: How will the part see loads? Compression/Tensile/Shear? Design: marry the printer process with material and intended use I can tell you that for my material that I use (Vero material family) it can be on the brittle side in terms of impact and or thin wall features. A 3D printed thin wall battery box in Vero material will be no match for a ABS molded battery box. Any loads perpendicular to a thin wall with a open end will not want to flex and just break. Printing these days has the ability to combine hard plastics with "rubber like" material to create varying durometers of your choosing. This may be much more in depth than you wanted, but things to think about. If this is a crawler/trail driver a printed box should be fine. I would hesitate printing a box for a basher though. Last edited by smitty2919; 02-07-2018 at 06:58 AM. |
02-07-2018, 11:46 AM | #39 |
About fillets, with a 0.4 - 0.5mm nozzle the smallest radio for the fillets will be 1mm, less than that is almost not apreciable, although I use sometimes don to 0.5mm radio fillets. About material, it depends what is the part final use. If it is decoration or non functional prototype or a part that needs to be hard but not exposed to heat at all then use PLA For mechanical parts you can use PETG, Nylon, or even PC. PETG is the easiest to use and will get more mechanical accuracy than the others. Nylon or PC produce very strong parts but they are difficult to handle materials on a desktop 3D printer. ABS in may opinion is quite useless if compared to PETG on a desktop printer. |
02-08-2018, 01:19 PM | #40 | |
It has to be printed with a controlled environment to prevent warping and ventilation to reduce brain damage. You also have to calibrate your printer's steps/mm or scale your print to compensate for the contraction that occurs when it cools. ( You should check calibration of steps/mm anything you want dimensional accurate parts since every filament type has a different coefficient of expansion). With ABS you can make really strong glue joints using acetone and ABS does a better job of holding heat set threaded inserts. ABS isn't as hygroscopic so you have less issues with moisture/having to dry your filament. Currently ABS and PLA are less expensive- hopefully this will change as more people are using PETG. So ABS is just another tool in toolbox of 3D printing. I just finished up printing parts for a new 3D printer build and they came out really nice. | |
Got a 3D printer on the way, got a design question - Similar Threads | ||||
Chassis design question? | firstumustcrawl | General Crawlers | 2 | 07-26-2014 04:43 PM |
general design question... | celt | Axial Yeti | 4 | 07-11-2014 10:39 AM |
Chassis Design Question | builder | General Crawlers | 4 | 04-03-2013 03:21 PM |
WK wheel design question | Douginala | HPI Wheely King | 6 | 08-12-2008 02:48 PM |
