01-26-2018, 07:36 PM | #21 |
Pebble Pounder Join Date: Nov 2014 Location: Camby
| Re: What hex drivers you using?
You wouldn't be dissapointed
01-26-2018, 07:59 PM | #22 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I've had a bunch over the years. Consider things that you may or may not like... things like shaft length, magnetic or non-magnetic tip, handle diameter and shape ( round handles can be irritating as they easily roll off of tables), ball-end tip or box tip, replaceable or fixed shaft, and hex material. Quality durable drivers are worth the money imo even though they're going to generally cost more. My older Hudy, MIP, and Dynamite hex drivers have been my favorites. Least favorites have been my ( also older) Great Plains, Hobbico, and Duratrax brands for one reason or another. |
01-26-2018, 08:27 PM | #23 |
Newbie Join Date: Jul 2017 Location: Northern
I use the team associated driver set. Worked fine for over a year now. How ever my 1.5 has twisted from applying to much pressure. Still works tho.
01-26-2018, 08:40 PM | #24 |
Rock Stacker Join Date: Jul 2015 Location: Law. Co
| Re: What hex drivers you using? |
01-26-2018, 09:14 PM | #25 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
I found Wiha not reliable. Now changed to MIP and hopefully they last longer than Wiha.
01-27-2018, 09:02 AM | #26 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
I have a set of integy’s that I have had for 8 years and have had no issues with them. Sent from my iPhone using Tapatalk |
01-27-2018, 09:13 AM | #27 | ||
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: What hex drivers you using? Quote:
Great value in the Dynamite drivers. Quality and Price. | ||
01-27-2018, 05:07 PM | #28 | |
Newbie Join Date: Jan 2018 Location: US
Sent from my SM-N950U using Tapatalk | |
01-27-2018, 05:58 PM | #29 | |
Newbie Join Date: Jan 2018 Location: Alabama
Sent from my SAMSUNG-SM-N900A using Tapatalk | |
01-27-2018, 06:38 PM | #30 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
I ordered a set for eds yesterday and ordered a wiha precision handle ball hex set today from amazon. Hopefully I’m good for a long time now lol. Thanks for all the help |
01-27-2018, 09:04 PM | #31 |
Rock Stacker Join Date: Jan 2018 Location: Madison
Congrats on the new tools! I got the MIP's and bought the Hitachi electric screwdriver and it was the best investment for RC tools I have made yet. It saves so much time and torment on the hand/forearm. The screwdriver has 21 clutch settings, which makes it easy not to strip stuff. https://www.amazon.com/Hitachi-DB3DL.../dp/B004Y74AU6 |
01-28-2018, 10:24 AM | #32 |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
I had the same question when I first started RCing. I found MIPS to be reasonably priced and had great reviews. They are very well fitted to the hex bolts. Snug, secure fit; super durable. In a year of light wrenching I dont see any signs of wear on my MIPS set. Things will last me ages. Also, the inferior brands; as stated before, wear out their shape and strip the bolt heads. Worth spending extra now to avoid that, imo. Sent from my VS987 using Tapatalk |
01-28-2018, 01:21 PM | #33 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
I use the MIP speedtips, so far 0 wear, and 0 stripped screws. with my dewalt screwdriver (best christmas present ever) |
01-29-2018, 08:41 AM | #34 |
Quarry Creeper Join Date: Jan 2006 Location: Orlando
| Re: What hex drivers you using? I use MIP speedtips with a Bosch screwdriver for the most part. For manual hex drivers, I use Wera (most comfortable handles on drivers I've ever had). I've had associated in the past (still do actually) and the aluminum handles are ridiculously uncomfortable when having to use more than minimal force to loosen something.
01-29-2018, 09:41 AM | #35 | |
Sent from my Nexus 5 using Tapatalk | |
01-29-2018, 10:35 AM | #36 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
Dynamite makes a couple sets, so for those who are recommending the Dynamites, it would be most helpful if you mentioned which set. I use the premium Dynamite machined set and I love them: https://www.amainhobbies.com/dynamit...dyn3080/p79789 The reason I went with this set was because the handles are hollow, which makes them very light weight. As silly as that sounds, it makes them a lot less fatiguing when you're working with them for a while. My SAE set is a cheap Hobby King set with solid aluminum handles. The tips are surprisingly hard and have proven very durable, but the weight of the handles makes my hands cramp if I'm doing a lot of continuous work with them. Secondly, the machined Dynamite set has a plastic swivel at the end of the handle that is incredibly useful if you rest the end of the handle in your palm while you use your fingers to turn. This is how I use them so that I can always ensure that the tip is well engaged into the screw, and having that spinny plastic piece riding in my palm makes them that much easier to turn. I've had the Dynamite set for a few years now, and they still work as well as new. I use the hell out of the 2mm, and I use the 1.5mm pretty often too. They both still fit snugly enough into the tip of a screw that they'll hold the screw while I search for the hole to put it into. |
02-14-2018, 05:42 PM | #37 |
Pebble Pounder Join Date: Apr 2005 Location: Australia
My older ones are all Hudy which I can't fault, super accurate, strong tips and last ages. Some of my newer ones are Arrowmax which seem very good also, no issues as yet. I did try Snap-on early on and found them to be not as accurate as Hudy, they would strip out 1.5 and 2.0mm screw heads regularly.
02-14-2018, 05:55 PM | #38 |
RCC Addict Join Date: Aug 2008 Location: Paulina
VP, I have broken one 1.5mm tip so far.
02-15-2018, 06:11 AM | #39 | |
https://www.amainhobbies.com/dynamit...dyn2904/p38303 The knurled handles get a little uncomfortable after long wrenching sessions but the fit is pretty precise and it is hard to find a better set of drivers for $20. | |
02-15-2018, 06:22 AM | #40 |
What hex drivers you using? - Similar Threads | ||||
Hex Drivers? | Bananaclip | Tools, and Procedures | 16 | 11-06-2008 07:40 PM |
I need hex drivers | BADNBADN | Tools, and Procedures | 6 | 06-20-2005 08:25 PM |
