02-08-2018, 02:10 PM | #1 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Must have drill bits and taps?
I'm looking to supply my building needs and wondering what the must have sizes are? I know 3mm and 8-32 are top of my list, what others are common in buliding.
02-08-2018, 03:47 PM | #2 |
| Re: Must have drill bits and taps?
It all depends on which hardware you intend to use- SAE or metronic. Besides taps and dies, you'll need tap size drill bits and clearance size drill bits. Download a Starrett drill chart, it has all of the most common sizes for tap/drill operations, or you can use the formula of 70% of major thread pitch = drill size for tapping the hole.
02-09-2018, 10:46 AM | #3 |
Metric is most ill use. 3mm is the most used since I'm working to get rid of the 2mm hardware on main parts. And 8-32 is for links since I'm making my own.
02-09-2018, 11:42 AM | #4 |
I have 2.5mm for cage supports mainly and for items on my 1/5 motorcycle but rarely use I wear out at least Four 3mm taps, One die and 2.5mm drill bits a year I also have 4-6mm for my 1/5 scale stuff On a rare occasion I will use a 8-32 tap and die. |
02-12-2018, 03:21 PM | #5 |
Numbered drill bit set has been a great RC workshop tool imo. I've got an old steel boxed flip up set goes from #1 to iirc #60, I've replaced some of them a couple times over the years. Edit: Also have 3mm, 2mm drill and tap sets along with a set of metric tap/dies from Harbor Freight that have been ok, not my go to tool brand/store though lol. |
02-12-2018, 03:51 PM | #6 |
My bro in law has some 3mm taps. One 3mm x .05 and 3mm x.06 which is more common in rc?
02-12-2018, 05:38 PM | #7 |
| Re: Must have drill bits and taps? |
02-12-2018, 08:01 PM | #8 |
Ok thanks ill probably just brough it. Not going to be tapping any metal to start with I have a cutting board with my name on it that needs parts made out of it.
02-12-2018, 08:49 PM | #9 |
You probably know but get the correct type of taps. Ie, through hole, blind hole, etc. For years I kept using and breaking du-bro hand taps. At $8 each, I dunno how many I bought over the years. Then I got schooled on drill bits and taps by Rob at SMW. |
02-12-2018, 09:01 PM | #10 | |
| Re: Must have drill bits and taps? Quote:
I just picked up some du bros taps, if you dont mind elaborating I'm curious to know how i might end up misusing these taps. I plan on taping by hand. EDIT: I just did some light reading and I think I follow you now https://www.yamawa.com/en/support/tips/pdf/tips-007.pdf Last edited by HumboldtEF; 02-12-2018 at 09:07 PM. | |
02-12-2018, 09:05 PM | #11 | |
Tapping by hand is for 1947! Haha, I kid. Buy some machine taps, put em in a drill and hammer down. For a “through hole” hole, below. | |
02-12-2018, 09:46 PM | #12 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
For tapping metal, a good quality cutting and tapping compound is a must IMHO. And, don't let anyone tell you "any old oil will do", well maybe in a pinch. Depending on the material, hand tapping, slow and easy, backing out occasionally, will help prevent breakage. I tap mostly aluminum and even though you think aluminum is soft enough you needn't worry about the drill or tap getting dull, trust me, they do. Replace when necessary so you don't have to deal with a broken bit or tap in a blind hole. Very aggravating, especially when its the last hole in an hours worth of work. Yup, 3mm x 0.5 pitch is standard in the RC world as far as I know, and maybe everywhere else as well. Somehow ended up with a 3mm x 0.45 pitch and it drove me crazy for a day. The package was marked 3mm x 0.5 but it wasn't until I checked the tap itself I found out my problem. Took a huge magnifying glass for my old eyes to read the info on the tap itself. |
02-12-2018, 11:27 PM | #13 | |
Most nerve racking tapping I did was the hack 'n tap on my xj transfer case. And knowing if I mess up I would have to replace the transfer case or pull it out and replace the output shaft. Glad I didn't mees up that one. | |
02-13-2018, 06:39 AM | #14 |
Another thing I’ll mention is have separate taps for different materials. Ie, I now have taps I only use for plastic tapping and taps I only use for metal tapping.
02-13-2018, 06:49 AM | #15 |
Makes sense.
02-13-2018, 10:17 AM | #16 |
The number of flutes on the tap generally dictate what type of metal they will work best in., 2,3 and 4 flute are very common. If you're going to use M3 for the bulk of your holes, just buy a pack of #40 drill bits for the tap hole and .125 (1/8th inch) for the clearance hole. Tap Magic is a good all purpose tapping/cutting fluid. I use BoeLube "pink" for aluminum and SS. IMO, the biggest and easiest mistake to make when your start tapping holes is to start the tap crooked. It will quickly bind up and snap off. Good times ! I use a 4 flute "nut" tap to start a few threads then change over to a 2 flute through hole to finish the job. |
Must have drill bits and taps? - Similar Threads | ||||
good quality drill bits, what kind and where to buy? | warren | Tools, and Procedures | 11 | 02-11-2014 10:01 PM |
mip hex driver or drill driver bits with racheting handle | 507Eli | Tools, and Procedures | 2 | 12-17-2011 05:07 PM |
Hex Drill bits | Lemonlegs28 | Tools, and Procedures | 11 | 01-03-2011 11:08 PM |
metric drill bits? am i missing something? | RCMFMaxxMan | Tools, and Procedures | 10 | 09-23-2008 10:53 AM |
The RIGHT drill bits - Post up!!! | HannibalLecter | Tools, and Procedures | 1 | 06-21-2006 08:10 PM |
