Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Intricate tape and masking lines for paint
Old 03-11-2018, 03:06 PM   #1
Default Intricate tape and masking lines for paint
I initially posted this under Paint and Body, but seems appropriate for Tools and Procedures threads as well.
I'm working on painting my '73 Proline Bronco body. I'm doing the flares in a different color than the body. The lines and curves of these are fairly tight and fine. I attempted to use narrow Tamiya masking tape (1/8"), but every time I tried to make the radius of the fender line it would crinkle up and not fully adhere to the body. Plus all those little wrinkles and crinkle lines are going to let that paint just bleed right under. No bueno.
I ended up going to my local auto parts store and picked up some vinyl pin striping tape. (also about 1/8") The vinyl tape easily allows you to make nice tight radius's and turns and remains flat with no wrinkling and crinkling. It also adheres really well to the lexan. So, my procedure was to do my outer most edge of the line with the vinyl tape to get a nice, clean and crisp line, then go back and do the broader masking with blue painters tape as per usual. I was also able to do up in the roof line and windshield line with this method since these areas were pretty tight as well. A roll of the pin stripe tape in this size was $2.59, so pretty good deal to boot!
mewalsh100 is offline   Reply With Quote
Old 03-15-2018, 12:39 PM   #2
Default Re: Intricate tape and masking lines for paint
I generally use liquid mask for this stuff. I like the idea of the pin striping though.
JimmytheBarrel is offline   Reply With Quote
Old 03-16-2018, 05:54 AM   #3
Moderator
JatoTheRipper's Avatar
Liquid mask works great if you have patience.
Old 03-16-2018, 10:05 AM   #4
I prefer to use 3M fineline tape, then the Tamiya 6mm. But if I’m doing 3 or more colors I use the fineline and liquid mask.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 03-17-2018, 10:56 AM   #5
I always cover the areas with tape and then draw on my design and use an Exacto knife to cut out the design. That way, I can peel away the tape, spray one color, layout the next lines,cut and repeat.
HoosierClod is offline   Reply With Quote
Old 03-17-2018, 11:04 AM   #6
Spray it on, 4 even coats dry and ready in 6 hours
Old 03-17-2018, 12:22 PM   #7
Moderator
That's the easy part. Cutting it out with a knife is the tedious part.
Old 03-17-2018, 02:23 PM   #8
I found a new #11 blade, not in a handle, but wrapped with tape for a grip, easy to spin and follow curves
Hang up and Drive
Old 10-31-2018, 04:48 AM   #9
Hal
A great trick I learned in the 1:1 world if you are doing hardbody is to put on tape and spray with the original color you put tape over. Then spray the new color. This way if you get ANY bleed under tape it will be original color. Also if you let it dry totally the tape may lift some of the paint anyway. Remove tape while paint is still slightly wet, or cut at edge of tape with razor so it will be a nice clean edge. Caution cutting on lexan if you go into the body it will probably crack there eventually. Good luck.
Hal is offline   Reply With Quote
Old 10-31-2018, 06:53 AM   #10
We’ve always used a clear intercoat after taping. I use HOK S100
Hang up and Drive
Old 10-31-2018, 06:20 PM   #11
Has anyone used knifless tape to make designs?
https://www.youtube.com/watch?v=FknbgFrUALI
https://www.youtube.com/watch?v=0xUfikwcWA4
Inspector86 is offline   Reply With Quote
Old 11-16-2018, 05:17 PM   #12
I have a vinyl plotter I use to cut whatever I want so I cheat a little.
KyWoody is offline   Reply With Quote
Intricate tape and masking lines for paint - Similar Threads
Plasti dip as masking tape? Betts818 Paint and Body 14 06-19-2016 03:48 PM
Masking and paint bleed issues? My tip cor clean lines. Heckler Paint and Body 2 12-18-2014 07:56 PM
liquid masking tape......... bob1961 Paint and Body 7 03-28-2014 08:32 AM
Liquid masking tape. avanord Paint and Body 7 10-13-2012 08:39 AM
Masking tape... BagoXCAlum Chit Chat 7 05-22-2006 09:06 PM
