07-20-2018, 08:17 PM | #1 |
Rock Stacker Join Date: Jun 2014 Location: Lewisburg
| Socket for removing studs from Boom Racing wheels?
I picked up a set of Boom Racing Terra 8 hole wheels for a build I want to do. The wheels look fantastic, and fairly close to how I remember the wheels on my grandparents' 1989 Suburban. I went to try them on my truck, but I noticed that the tiny screws that hold the hub cap on need a socket that is much smaller than anything I have. Does anyone know what size I need for this, or who makes one? I saw a 2.5mm tip the other day, but they don't seem very common.
07-20-2018, 09:43 PM | #2 |
Newbie Join Date: Mar 2017 Location: Chandler
| Re: Socket for removing studs from Boom Racing wheels?
I cannot be sure since I do not have those wheels, but it looks like a Wiha 2.0x60 265P would work. I use something like this one on my Gmade wheels that have very similar looking hardware. Good luck!
07-20-2018, 11:46 PM | #3 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Should be like 2..0mm hex 0 Sent from my vivo 1723 using Tapatalk Last edited by Teng; 07-20-2018 at 11:48 PM. |
07-21-2018, 12:06 AM | #4 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I believe these are 1.55 wheels? They utilize a 2mm socket. You can get a 2mm cap-head screw and turn it upside down then insert it into any driver/ tool handle or you can pick up a 2mm socket driver like a Wiha #26520 nut driver... ebay, amazon, RPP Hobby ( Gear-Head brand), etc.
07-21-2018, 12:38 AM | #5 | |
| Re: Socket for removing studs from Boom Racing wheels? Quote:
Yes, 1.55. Thanks everybody! | |
07-21-2018, 04:30 AM | #6 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
I used a bolt & glued it into a piece of aluminum tube. Worked perfectly for my scale bolts on the beadlocks Sent from my SM-S975L using Tapatalk |
07-23-2018, 11:30 PM | #7 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Wish I had seen this before I bought one. I do have a nice socket tip and handle coming from lockeduprc tho.
07-24-2018, 06:52 AM | #8 |
| Re: Socket for removing studs from Boom Racing wheels? Hopefully you got the HD one. The standard, 2-per pack scale hardware tips strip way too easily. I either get only 2 or 4 wheels (I forget) out of a tip before it's too worn to use. I haven't used the HD tip on more than 2 wheels so I can't comment on how long it will last.
07-24-2018, 07:13 AM | #9 |
I got the HD tip after reading this NOT suggested for use with bead lock wheels. For those applications, use part# 730-2HD |
07-24-2018, 07:16 AM | #10 |
| Re: Socket for removing studs from Boom Racing wheels? |
07-25-2018, 03:04 PM | #11 |
Rock Stacker Join Date: Jan 2018 Location: Ivins, the Red Rock Southwest
Noobie and beadlocks, same tool problem. ordered a couple sockets from RPP but didn't want to wait so . . . thanks to this thread I made this: m3X10 stainless cap screw locked into the 4mm hex wrench Handel. works like a charm.
Socket for removing studs from Boom Racing wheels? - Similar Threads | ||||
Boom Racing AEGIS™ 1.9 High Mass Beadlock Aluminum Wheels | durok | Tires and Wheels | 4 | 06-22-2018 08:55 PM |
Boom Racing 1.55 Yota LC Scale Beadlock Wheels | JatoTheRipper | Tires and Wheels | 25 | 06-19-2017 07:50 PM |
Boom Racing high mass wheels | T4rscott | Tires and Wheels | 8 | 06-02-2017 05:40 AM |
Boom Racing wheels | Jeckler | Chit Chat | 13 | 05-30-2016 08:49 PM |
removing shocks / links from ball studs | benny27 | Losi Micro-Rock Crawler | 1 | 01-22-2012 07:38 AM |
