12-02-2018, 03:12 AM | #1 |
| Laserjet acetone print transfer
If you reverse an image you can print it with a laser jet printer and soak it with acetone to transfer it. I just set the paper on the car and carefully rubbed nail polish remover into it for 30 seconds to a minute and pealed it off. EDIT: DON'T USE ACETONE ON LEXAN! No idea if acetone is safe for lexan. I did it on PETG and primer. The image transfer is sub par but had exactly the look I was going for. For a better image transfer use polyurethane clear or a gel medium and let dry a few hours then scrub till the paper falls apart. Mostly I have seen this done on wood but it can work on glass and paint. I actually used non acetone fingernail polish remover for this one. I have 3 fingernail polish removers one is mostly acetone, the other 2 are a pink and a blue non acetone remover, all 3 work about the same. Last edited by Voodoobrew; 12-04-2018 at 01:33 AM. |
12-02-2018, 08:18 AM | #2 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: Laserjet acetone print transfer
So thats just a pic on paper n the ink transfered from the paper to the body? Thats pretty cool. Plus it gave it that worn look Sent from my SM-J327VPP using Tapatalk |
12-02-2018, 08:26 AM | #3 |
Yes the warn look is from the transfer not the print.
12-03-2018, 08:51 AM | #4 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
Awesome technique, but Acetone destroys Lexan. It will melt it if left soaking, even with brief exposure it leaves the Lexan extremely brittle. I'll definitely be using that method where I can. (PS - Unrelated but I've been experimenting Ethyl Acetate [non-acetone nail polish remover] for smoothing PETG prints and it works pretty well - haven't tried a vapor method wiping w ith a Q-tip works really well) |
12-03-2018, 09:14 AM | #5 |
RCC Addict Join Date: May 2015 Location: Price Twp.
You would be better served using waterslide paper for what ever printer you might have.
12-03-2018, 02:57 PM | #6 | |
| Re: Laserjet acetone print transfer Quote:
Definitely use with care. | |
12-03-2018, 03:14 PM | #7 |
Just noticed the rig, Im printing your designs as I type this. Thanks for putting it out there. |
12-04-2018, 01:25 AM | #8 |
| Re: Laserjet acetone print transfer That's why I originally bought this fingernail polish, i also have the pink methel acetate, I couldent get either one to smooth my PETG prints. could you tell me about your results with times? I used Priline PETG not that that should matter.
12-04-2018, 01:49 PM | #9 |
| Re: Laserjet acetone print transfer I've got very limited data so far but I'll PM you later about this.
12-04-2018, 02:17 PM | #10 | |
Quarry Creeper Join Date: Jun 2015 Location: France
(clear for the whole ice-cream theme) or outside with hard-body and lexan (clear for door numbers, white for roof flag and Daisy's shirt) | |
12-04-2018, 03:13 PM | #11 |
I thought this looked familiar! I was wondering how you did it. Priline petg is great if you preheat to drive out moisture. I have a jerky maker converted to filament dryer. Their pla is kinda terrible though. |
12-04-2018, 07:03 PM | #12 | |
My most recent batch is the Amazon basics Petg so far its good. Last edited by Voodoobrew; 12-04-2018 at 07:08 PM. | |
12-04-2018, 07:12 PM | #13 |
| Re: Laserjet acetone print transfer |
12-04-2018, 10:20 PM | #14 |
dry filament also bridges better. Would be rad to use pla for supports only though, sounds like a decent idea for dual extruders if the oozing doesn't get out of control. I would want a petg prime pillar at least.
12-04-2018, 11:03 PM | #15 |
| Re: Laserjet acetone print transfer It will be 2 side by side bowden e3d V6's so i think no need for a prime pillar, It would be too risky having filaments with 50 degree different temps using the same extruders.
05-23-2020, 10:12 PM | #16 |
Pebble Pounder Join Date: May 2020 Location: DMV
love it
05-23-2020, 10:33 PM | #17 |
Rock Stacker Join Date: Oct 2014 Location: Raeford
Laser jet, Inkjet right? My Make gear has oozing issues at times, I have 3 e3d V6's been thinking of converting my Makergear M2 to these extruders. Seen some folks with very good results that way. Have the parts to put a Prusa I3 together, why I have the E3d's, one is a knockoff. I've used a bit of printable decal paper on some custom Diecast that I use to do, and on the outside of my RC bodies. I assume when reversing for the inside you have to trim close also? Wish you could get white onto clear paper with an Injket. |
Laserjet acetone print transfer - Similar Threads | ||||
The Acetone Tire Removal Method | roachslayer | Tires and Wheels | 3 | 05-19-2017 05:30 PM |
CI foams and acetone? | OSRC | Tires and Wheels | 19 | 04-29-2017 09:13 AM |
No Acetone Joy | j.krug | Tires and Wheels | 7 | 12-10-2016 11:37 AM |
Acetone damage? | RubikonKid | Tires and Wheels | 20 | 12-25-2013 05:50 AM |
