01-03-2019, 10:39 AM | #1 |
Newbie Join Date: Sep 2018 Location: Bates City
| Tube bender question |
01-03-2019, 03:07 PM | #2 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Tube bender question That brake line you have may have to thin of a wall to get that tight of a bend with out linking. Having said that, this is my DIY bender. This is how I keep most of my bends from kinking. I use a heavy flat washer, a 1/8" spacer, or 1/4" spacer depending on the size of the tubing I'm bending. The spacer should be the same size as the tubing you want to bend. I turned a hardened socket head bolt down until I have a very thin lip to hold the washer tight... Hope that helps you out a little. Let me know if I can help you any more! Ernie Last edited by CODYBOY; 01-03-2019 at 03:22 PM. |
01-04-2019, 09:54 AM | #3 |
I see, the tube must be kept from expanding upward....and a coved inside die isn't necessary....
01-17-2019, 12:35 PM | #4 |
| Re: Tube bender question |
Tube bender question - Similar Threads | ||||
my tube bender........... | bob1961 | Tools, and Procedures | 109 | 04-11-2020 05:36 AM |
tube bender | timmy85 | Tools, and Procedures | 17 | 02-20-2010 04:58 PM |
Tube Bender Question | rcr3fan29 | Tools, and Procedures | 3 | 02-08-2006 01:20 PM |
