03-04-2019, 04:21 PM | #41 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: unexpected uses for tools (and techniques) Share Yours!
I was just textn my dad n showin him pics of my leaf sprung project n my monster truck project n got on the subject of locktite on bolts. He said not to use locktite on them, it could cause them to strip or break off. So far, knock on wood, i havent had that problem. But he said use pepto bismol as locktite alternative. I never woulda thought of that. Wen it dries, it does turn to a chalky paste kinda like locktite does. Might b worth a try. Shoot, a bottle of pepto would last forever as a locktite alt. Plus if u feel sick workin on your tiny trucks, just take a swig lmbo Sent from my SM-J327VPP using Tapatalk |
03-05-2019, 08:21 AM | #42 | |
| Re: unexpected uses for tools (and techniques) Share Yours! Quote:
Some people also use nail polish as an alternative to Loctite. | |
03-05-2019, 12:55 PM | #43 |
I was gonna say the same thing, Blue (or medium) is fine for RC but dont use the red as its intended to be permanent and requires heat for removal. Though your fathers idea for an alternative threadlock is still pretty cool and definitely unique More info on the different kinds of Loctite here The Difference Between Red, Blue, Green and Purple Threadlockers - Henkel Adhesive Technologies Blog Last edited by HumboldtEF; 03-05-2019 at 12:57 PM. |
03-18-2019, 02:13 AM | #44 |
Laparoscopy forceps I don't have a pair but I'm considering getting them. I bet they would be super handy for pushing/pulling wire, and other jobs in hard to reach spaces. You can find them for less then $30 |
03-19-2019, 04:15 AM | #45 |
Newbie Join Date: Oct 2006 Location: Emporia
To add to High Plains post with the "bearing" cleaner jig... I use an old pickle jar to catch the "used" bearing spray, over time it will fill up if you keep lid on tight , then if I needed to clean some excess grease/oil up I can dip a corner of rag in my jar instead of grabbing the "new" can of cleaner. Re use it so to speak. |
07-08-2019, 11:51 PM | #46 |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
I use a chop stick to help remove and test bearings Both ends are different sizes, so it works for almost any size of standard rc bearing.
09-08-2019, 11:57 AM | #47 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Small hole gauges work nicely to remove bearings from blind bores. |
11-04-2019, 10:40 AM | #48 |
Newbie Join Date: Sep 2019 Location: Channahon
I was just thinking yesterday how much extra functionality I've gotten out of my hot air rework station. It's just a cheap unit, but I used it for a bunch of different stuff: Shrinking heat shrink tubing - 150°F Flashing off fresh paint, including spray paint and modeling acrylics - 120°F Melting small hairs and stubs on 3D prints - 210°F Warming 3D printed pieces to add bends/shaping - 190-220°F Decals that have wrinkles or edges that won't quite stick down, hit them with a bit of air, then hold the decal in place for 20 seconds - 120°F This is the unit I bought: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
11-04-2019, 12:10 PM | #49 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
I've found that my used shock oil is perfect drilling lubricant. Saved my bits while drilling stainless steel using it.
11-13-2019, 09:44 AM | #50 | |
Rock Stacker Join Date: Jul 2019 Location: Bullard, TX
12-09-2019, 11:23 AM | #51 | |
Quarry Creeper Join Date: Dec 2019 Location: Woodstock
| Re: unexpected uses for tools (and techniques) Share Yours! Quote: How about the same deal, with a twist Pep | |
12-31-2019, 11:14 PM | #52 |
Welding requires one to acquire many clamps. Half of all welding projects is figuring out how to hold stuff, This also goes for RC building, so simple clamp set can be made using clothespins. Pretty sure this not a new idea, but for others that may not have though about it, a picture. Also seen a lazy susan, great for painting pep |
01-01-2020, 01:52 AM | #53 | |
I wanna be Dave Join Date: Sep 2019 Location: US
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
01-01-2020, 06:04 AM | #54 |
Scale clamps ........... 10 for 25 bucks, power coating extra. What's funny, everyone has these goofy helpers used for building. Some are usable, interesting, some only the inventor understands. pep |
01-15-2020, 08:08 PM | #55 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
Sent from my LM-G710VM using Tapatalk | |
05-03-2020, 06:04 PM | #56 |
Newbie Join Date: Jun 2011 Location: Rohnert Park
Soldering iron to heat grub screws when Loctite was used. A rubber band around plier handle to use as a clamp. Plano tackle box as a toolbox .
07-08-2020, 11:07 AM | #57 |
Rock Stacker Join Date: Jan 2011 Location: Columbus
JB Weld...for lexan body?!?!?! I have a few areas that cracked or broke, applied some JB weld, inside and out, now I have a nice little bondo patch along the bottom of the door. It's functional and pleasing to look at on the old Blue Honcho. |
10-01-2020, 04:31 PM | #58 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
Soldering iron to burn rust holes in body. Yes, I use a completely different tip when I solder Also used my chassis stand to put my body on and spin it to paint! Sent from my iPad using Tapatalk |
05-11-2021, 11:20 AM | #59 |
Quarry Creeper Join Date: Dec 2015 Location: NY
| Re: unexpected uses for tools (and techniques) Share Yours! |
05-13-2021, 09:21 AM | #60 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
A chain saw raker file for filing the depth gauges on the chain. Around 6” long and sharp. I use it to open the holes on one side of a servo for mounting on my Trx4. Only takes a few licks. I also use it to sharpen my splitting axes as well. Takes a lot of metal off very smoothly. Pferd is the actual brand I use. |
unexpected uses for tools (and techniques) Share Yours! - Similar Threads | ||||
Unexpected power loss | bbos12 | Axial Yeti XL | 17 | 12-23-2016 07:40 PM |
Project Wraith in an Unexpected location | eunique | Scale Videos! | 0 | 10-08-2014 11:24 AM |
What is something unexpected you have found while crawling or scouting a spot? | Jslick | Chit Chat | 53 | 08-16-2011 02:51 PM |
Unexpected and frequent stall | rooktakesqueen | Team Losi Comp Crawler | 2 | 05-21-2010 06:54 PM |
