New Garage/Shop Build Bought a new house a few weeks ago and one of the first things on the list was to build out the garage. Biggest things on the list were more/better lighting, a dedicated bench for the CNC router and computer, and more bench space for the lathe and drill press. This is what I started with. 2 car garage, 20'-0" wide by 23'0" deep, with a 9'-6" ceiling. No insulation or drywall, and minimal power. https://live.staticflickr.com/65535/...2988a173_c.jpgIMG_20200106_161006 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...256a2677_c.jpgIMG_20200106_161020 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...74b7d222_c.jpgIMG_20200106_161027 by Casey Childs, on Flickr Stopped at Home Depot on my way home from the closing to buy 20 sheets of drywall and fiberglass insulation. Got to work right away. Progress after a few hours: https://live.staticflickr.com/65535/...76409e08_c.jpgIMG_20200106_210924 by Casey Childs, on Flickr Day or two later: https://live.staticflickr.com/65535/...e7bfc595_c.jpgIMG_20200111_103511 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...544dc819_c.jpgIMG_20200111_103506 by Casey Childs, on Flickr Got two rows up on the walls and moved to the ceiling. Even with lightweight drywall, a drywall jack is a must. https://live.staticflickr.com/65535/...cff3b97e_c.jpgIMG_20200111_225942 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...28e6d630_c.jpgIMG_20200112_122336 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...6446001f_c.jpgIMG_20200112_173725 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...6e79904e_c.jpgIMG_20200112_210639 by Casey Childs, on Flickr After the ceiling was done I finished the short sections of the walls. Even the white drywall makes a huge difference in how bright it is. https://live.staticflickr.com/65535/...a6a9c4b7_c.jpgIMG_20200123_214052 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...6b1011a6_c.jpgIMG_20200123_214054 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...c26d091a_c.jpgIMG_20200123_214056 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...da6c950a_c.jpgIMG_20200123_214059 by Casey Childs, on Flickr Here is what I will be using for lighting. 12 of these 4' long, 4000 lumen LED fixtures. Mounting them in a 3x4 grid pattern on two switches so I can only turn 6 on if I don't need operating room lighting. https://live.staticflickr.com/65535/...e90c52f9_c.jpgIMG_20200117_205309 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...8d48fa99_c.jpgIMG_20200117_205313 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...552767f7_c.jpgIMG_20200117_205325 by Casey Childs, on Flickr This is where I was at two nights ago. Drywall is done and the walls have been mudded. I started painting last night so I can move everything to the other half of the garage to finish the last half of the ceiling. https://live.staticflickr.com/65535/...ae06ea87_c.jpgIMG_20200125_144405 by Casey Childs, on Flickr |
Re: New Garage/Shop Build Needs more Lights ....... :mrgreen: And bigger machines :mrgreen::mrgreen::mrgreen: |
Re: New Garage/Shop Build Done yet? |
Re: New Garage/Shop Build Congratulations on the 2nd house and progression of life"thumbsup". I know by my email and PM's that a comp chassis maker is needed. |
Re: New Garage/Shop Build Quote:
Re: New Garage/Shop Build Update time. In the push to get the router back up and running I primered and and painted the two walls so I could set the router up in the back corner. https://live.staticflickr.com/65535/...949bd7a4_c.jpgIMG_20200131_212747 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...1c07626b_c.jpgIMG_20200129_204419 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...0056b419_c.jpgIMG_20200201_122517 by Casey Childs, on Flickr After I got that corner set up, I needed to start building benches to get stuff out of the middle of the garage so I could finish the ceiling. 8' x 2' x 32" bench for the lathe and drill press. It will get a shelf after I get drywall and paint done. https://live.staticflickr.com/65535/...9d692534_c.jpgIMG_20200206_222938 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...c6cb7a4e_c.jpgIMG_20200208_140926 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...ef8f1c8f_c.jpgIMG_20200208_140157 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...25661d74_c.jpgIMG_20200208_160350 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...c65d1dac_c.jpgIMG_20200209_133737 by Casey Childs, on Flickr Looking out the man door into the garage. Need to add a little more mud on the ceiling then I can sand and finish painting. This will be the router/computer bench in the corner. There is room for the vacuum and dust collector underneath out of the way and I will pip the vacuum exhaust up and out of the garage to help keep noise and fumes/dust down in the garage. https://live.staticflickr.com/65535/...4f1e8902_c.jpgIMG_20200209_220041 by Casey Childs, on Flickr |
Re: New Garage/Shop Build Any plans to epoxy coat the floor? That's probably the biggest thing I wish I had done before moving all my crap in... 12 years ago! It'd be so much harder now with the amount of stuff (some of it built-in) that's in the garage now that I can't even consider it. |
Re: New Garage/Shop Build Very nice. Tons of work, but it'll be worth it in the end. |
Re: New Garage/Shop Build Router table is in. Every time I set the router up, I go lower and lower. It makes loading material and bolting it down way easier. There's also room on the end for my desktop so I don't have to go inside to modify CAM programs any more. https://live.staticflickr.com/65535/...f70c7beb_c.jpgIMG_20200212_201413 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...412265cc_c.jpgIMG_20200212_214945 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...4f8ffe95_c.jpgIMG_20200212_215802 by Casey Childs, on Flickr https://live.staticflickr.com/65535/...2fee70f3_c.jpgIMG_20200212_215822 by Casey Childs, on Flickr |
Re: New Garage/Shop Build great job this gives me encouragement for my next garage |
