04-19-2020, 12:27 AM | #1 |
Quarry Creeper Join Date: Dec 2019 Location: California
| Lube for squeaky axel shaft joints
I'm looking for a lubricant for my TRX6 axel dog bone/CVD (I don't know which one it is) joints that squeak a lot. I'm using WD-40 silicone spray lubricant, which works, but doesn't last very long. What lubricant should I use? I run in pretty dusty/dirt-y conditions most of the time, and I don't really want something that the dirt can stick on to. I found something called WD40 PTFE spray, which forms a layer of really slippery material. I don't know if it's effective for squeaking though. Any recommendations? Thanks! |
04-19-2020, 12:37 AM | #2 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Lube for squeaky axel shaft joints
Pinewood derby dry graphite is the only thing i have used for years on everything but gears. It keeps things crazy smooth, polished and clean.
04-19-2020, 10:58 AM | #3 |
I have a small squeeze bottle of "Tri Flow" , which is a PTFE lube that I use on heim/spherical joints on my 1:1's, and it keeps the squeeks at bay for a long time. I run in dry/dusty conditions the majority of the time and haven't noticed it attracting dirt, at least, not enough to bother me. I'd give that WD40 PTFE a shot.
04-19-2020, 11:03 AM | #4 |
I use Fluid-Film. It is a great lanolin based general purpose lubricant/preservative available from any auto parts store.
04-22-2020, 06:54 AM | #5 |
I use silicone spray lube. That WD-40 PTFE stuff looks like it should work.
04-22-2020, 08:26 AM | #6 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
I use Purple Extreme on all the moving parts of my RC's except the bearings. When dry it doesn't attract dirt, can't really say if it will stop your squeak. A little pricey but I've been using the same bottle for about 3+ years now. I put it in a small applicator bottle to make it easier to handle.
Lube for squeaky axel shaft joints - Similar Threads | ||||
Center Drive shaft joints....lube or not? | big_poppa49 | Axial SCX-10 | 3 | 06-30-2016 10:28 AM |
Do you guys grease shaft/U joints? | big_poppa49 | Axial SCX-10 | 7 | 02-09-2016 09:05 PM |
Do you guys lube your shaft joints? | big_poppa49 | Axial SCX-10 | 7 | 11-22-2015 07:24 AM |
Rear Axel Output Shaft Getting Loose... | I SMOKE ROCKS! | Losi Mini-Rock Crawler | 0 | 01-12-2009 07:40 PM |
drive shaft u joints | Bknight | Newbie General | 9 | 10-12-2006 03:07 PM |
