How to remove very tiny stripped screw? How do I remove a tiny completely stripped screw? They're the ones on my Hobbywing Axe, the 3 tiny ones on the sides. I've got 1 full rounded, 1 partially rounded, and 1 that's intact. I've tried the rubber glove method, didnt work. I was thinking of using some JB weld, but the contact area is so small I'm not sure if it will grip. Any suggestions as to what I can do? Or am I stuck with an unmaintainable motor? |
Re: How to remove very tiny stripped screw? I don't own an Axe so I don't know where the screws are but a rounded screw (possible) solution is to use a drill bit equal or slightly smaller in diameter and drill the screw out. Sounds like it's too small to Dremel a slot and use a screwdriver. |
Re: How to remove very tiny stripped screw? You could possibly grab it with a hemostat. Dont own what you have either, so Im not sure how much space you have |
Re: How to remove very tiny stripped screw? Take pics so we can help. Not seeing what your looking at...I would grind off all bolt heads with a dremmel. Remove motor and replace the part that has the three grinded bolts on it. If it is a large part that cannot be replaced...I would dremmel two flat spots on the screw heads to grip with the correct pliers. |
Re: How to remove very tiny stripped screw? Quote:
I think if it was me I would try ( on the phillips head) to see if I could pry a very small flat-head screwdriver under the head and lift up enough to grab it with a very small pair of needle-nose pliers... then slowly try to extract it with the pliers. If it was the hex head screw, you might be able to jam or tap a cheap-o hex key into the hex-head and remove it that way... Or you might even be able to use a larger sized hex-key and shave it down on a few sides to be able to get it into the hex-head. To reverse drill/ tap the phillips head screw out... it looks pretty small so prob tough even if you had a small enough bit. |
