10-12-2020, 06:04 PM | #21 | |
| Print not sticking Quote:
Hang up and Drive | |
10-12-2020, 06:08 PM | #22 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Print not sticking Quote:
Ok, cool. Still can’t figure out why the print isn’t even touching the bed. Is there a setting in Cura that adjusts the Z Axis height? Sent from my iPad using Tapatalk | |
10-12-2020, 07:16 PM | #23 |
Did you dry your filament before use? Makes a big difference. Squash may be off, try offsetting your Z axis, or adjust height by leveling knobs.
10-12-2020, 07:16 PM | #24 | |
https://marketplace.ultimaker.com/ap.../ZOffsetPlugin Hang up and Drive | |
10-12-2020, 07:23 PM | #25 |
Another thought when I installed my Cr20pro I did have to set the print plateZ height in the first step as it is self leveling, not sure if you’ve done that on your model. Hang up and Drive |
10-12-2020, 07:27 PM | #26 | |
I have manual bed leveling on my model, thank you though for all of your help Sent from my iPad using Tapatalk | |
10-12-2020, 07:28 PM | #27 | |
This may be the problem. I normally keep it in a ziplock bag with a silica pack since the air is full of moisture here, but I left it printing overnight when it failed so this might be the problem. How do you reckon I go about drying it? Sent from my iPad using Tapatalk | |
10-12-2020, 07:32 PM | #28 | |
| Re: Print not sticking Quote: Thank you for the link! Just installed and trying now. Sent from my iPad using Tapatalk | |
10-12-2020, 07:37 PM | #29 | |
What I learned is most of my initial issues were caused by my lack of understanding the process, and adjusting things that were proper. My biggest chang for consistently producing prints is my PID tune numbers. They vary depending on my filament brand I use 4 different tunes, all for specific types. 1 is for ProtoPlasta PLA, 2 , ProtoPasta carbon 3, tpu’s and ,4 , PETG Hang up and Drive | |
10-12-2020, 07:53 PM | #30 | |
Yeah, I’m trying to learn it and not rip my hair out at the same time! How do you like the ProtoPasta PLA? I think I want to try multiple different brands and see which one I like best. Sent from my iPad using Tapatalk | |
10-12-2020, 07:58 PM | #31 | |
Printing a heat tower now! I think the Z Axis plugin helped, I just left it a 0mm though, so I don’t know if it did do anything. Sent from my iPad using Tapatalk Last edited by ScaleLifeNewbie; 10-12-2020 at 10:32 PM. | |
10-13-2020, 05:50 AM | #32 | |
Love it. I print primarily PETG, but this can be annealed I’ve been satisfied. Hang up and Drive | |
10-13-2020, 01:42 PM | #33 |
Half the time it sticks to the bed, half the time it just balls up. Still not sure what’s going on. I think I’m going to put on a new nozzle and or clean the current one and see if that helps. Sent from my iPad using Tapatalk |
10-13-2020, 01:45 PM | #34 | |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
fixed it...sorry Last edited by themountain; 10-14-2020 at 01:16 AM. | |
10-13-2020, 02:06 PM | #35 | |
| Print not sticking Quote: Sent from my iPad using Tapatalk | |
10-13-2020, 02:08 PM | #36 |
| Print not sticking
This may be a stupid question, but on the back left leveling knob, I have to have it twisted all the way up to be level. Does that mean my bed is warped or something else going on? The other 3 knobs are relatively close to the same. (Reference picture below) I used a straight edge and it’s not perfectly straight, but it’s very very tiny decline in the middle of the bed. Also, when I hit print, all fans except the power supply fan shuts off. Arrows are to show where the springs are in the picture Sent from my iPad using Tapatalk Last edited by ScaleLifeNewbie; 10-13-2020 at 02:14 PM. |
10-13-2020, 02:33 PM | #37 |
Quarry Creeper Join Date: Dec 2009 Location: Central IL
If you want more compression on your springs to make the bed more stable, go ahead and do so, then adjust the location of your Z limit switch accordingly. The plate that the knobs go through may be slightly bent, making one spring less compressed than the others. Not sure that's a big deal so long as all 4 springs have preload on them and the top of the bed is level. |
10-13-2020, 02:44 PM | #38 | |
Ok good to know. This is my first printer so I probably messed up somewhere either when I built it or in the slicer. I haven’t found anything in the slicer yet though. Sent from my iPad using Tapatalk | |
10-13-2020, 02:49 PM | #39 |
I'm a newb too, but I do remember having to mess with my Z switch height when I built it. Make sure there isn't any play in your Y axis rollers (beneath the bed) also. Mine was really sloppy on the guide rail out of the box.
10-13-2020, 07:34 PM | #40 |
Something bad is going on inside because the filament won’t come out of the Bowden tube, or go any further. I’m going to take the Bowden tube off and check it out. Will have update shortly. Sent from my iPad using Tapatalk |
Print not sticking - Similar Threads | ||||
throttle sticking | phhh | Rally | 10 | 02-02-2014 10:32 AM |
It was not me... That''s my story and I am sticking to it! | The Cow | Chit Chat | 4 | 12-23-2010 11:36 PM |
Sticking Brush | losikid | Electronics | 16 | 05-03-2010 08:43 PM |
Servo Sticking | J71 | Newbie General | 3 | 03-07-2009 11:38 PM |
sticking pictures | deadcell | Paint and Body | 2 | 03-06-2007 09:03 PM |
