02-27-2007, 02:08 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Brazing Chromoly ?
I'm starting my custom Angled solid axles and would like to use Chromoly tubing. Anybody know if it's possible to braze chromoly? like using the Harris safety silv rod If I had a TIG welder this would be a no brainer but I only have a 125 MIG welder which I may use Any ideas? Thank you RJ |
02-27-2007, 02:29 PM | #2 | |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
I would say the mig welding would be FAR stronger, but then I overbuild... | |
02-27-2007, 03:20 PM | #3 |
Rock Stacker Join Date: Nov 2006 Location: NOVA
For a RC brazing will be fine or soldering, chromoly is steel just a different blend.
02-27-2007, 03:20 PM | #4 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
i'd say mig it, its so much quicker, you can get a lot more done quickly than you can with brazing
02-27-2007, 03:42 PM | #5 | |
I have not picked up materials yet so in case I can find the size I need in Chromo can I MIG stainless ? | |
02-27-2007, 03:44 PM | #6 | |
02-27-2007, 04:53 PM | #7 | |
What wire do you recomend? gas? | |
02-28-2007, 01:28 PM | #8 |
i have used both the .035 and .023 solid mig wire with stainless, you can get much smaller beads with the .023, as for gas i use the argon/co2 mix. straigth co2 seems to make much more spatter. i'm also using a 240v system. hope this helps |
02-28-2007, 04:00 PM | #9 | |
Quarry Creeper Join Date: Jan 2007 Location: wilkes-barre
02-28-2007, 04:05 PM | #10 | |
I may weld the chromoly or I'll use stainless and weld or silver braze Not sure at this point | |
02-28-2007, 04:06 PM | #11 |
the one thing i dont like about stainless is that it is a PITA to drill, unless your using high quality bits.
02-28-2007, 04:27 PM | #12 | |
