04-22-2007, 06:53 PM | #1 |
Newbie Join Date: Apr 2007 Location: Modesto
| What do I use to braze mild steel?
I need to braze mild steel parts. I have a MAPP gas torch. Am uncertain what type of flux and rod to use.
04-22-2007, 07:05 PM | #2 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
how thick is the steel? if its too thick you will need an oxy/act. cutting torch with a brazing tip
04-22-2007, 07:13 PM | #3 |
| Not very thick
It is jack chain and coat hanger wire thick.
04-23-2007, 12:33 PM | #4 |
then youll be fine with a MAPP set up
04-23-2007, 12:36 PM | #5 |
| My concern is....
What type rod and flux to use. I am a newbie at it so any helpful info is much appreciated.
04-23-2007, 12:51 PM | #6 |
| Ok, ok...
Am I saying it wrong? I do not have a welder. I simply want to braze 1/8" or thinner mild steel joints with a MAPP gas torch and want to know what to use for the flux and rod?
04-23-2007, 01:00 PM | #7 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
use flux for the flux and silver solder for the rod, but its a spool, not rod.
04-23-2007, 01:24 PM | #8 |
| Thanks Dirk
I've tried that, I think. I am using flo-temp Silver Bearing Solder and Rubyfluid Soldering Paste flux. I cannot get the solder to stick. even after grinding and cleaning the surfaces to be joined.
04-23-2007, 02:55 PM | #9 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
I may be missing something but why not use Harris Safety-Silv 56 solder and Stay-Silv paste flux. Both should be available at any reputable(sp) welding supply shop.
04-23-2007, 04:20 PM | #10 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
This is what I use. Bernzomatic 85,000 PSI tensile strength, 1250F to 1750F working temperature Last edited by FrankyRizzo; 04-23-2007 at 04:26 PM. |
04-23-2007, 05:26 PM | #11 |
| Thank you
We don't have that brand here,but I did manage to get an 1/8" fluxed brazing rod, now I just have to try it out.
04-23-2007, 09:54 PM | #12 |
I bought them at Home Depot.
04-29-2007, 10:30 PM | #13 |
| ok great success!
I found out that I had not been using enough heat for the size of the join I was trying to braze. So I put an additional torch on the task, A bit tricky, but it woks job completed.
05-03-2007, 07:59 AM | #14 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
| Quick question...about how many brazing rods does it take to complete an average TLT tuber? I'm thining of starting a tuber, but I'm unsure of how many brazing rods I will need. I hate running to the store in the middle of a project, so I'd like to make sure I have enough, but I don't want to have 3 million extra brazing rods around when I am finished. And with that brazing rod, you don't have to use flux with it? How's the completed joint come out looking?
05-03-2007, 08:24 AM | #15 |
Adilynsdad too! Join Date: May 2004 Location: G ville
I use safety silver 56 and stay silver flux paste. Goes on like butter
05-09-2007, 06:23 AM | #16 |
RCC Addict Join Date: Dec 2006 Location: Flatwoods
| I am just now building my first complete tube chassis, a prerunner and it looks like it is going to take about 2.5 30" rods. I have built a truggy bed and bumpers before though and the first few times you will use a lot more rod than normal as you learn how to control it.
05-09-2007, 07:21 AM | #17 |
Ya, I picked up a pack of the bernzomatic rods posted above. One pack includes 2 rods....maybe 12" long. I started my tuber a few days ago and have gone through 1 complete rod and just started to use the other one. I think I'll b eable to make it to the finish with just those 2 rods if I am careful and don't make big gobby brazes like I did when I started. |
07-01-2007, 09:22 PM | #18 |
Rock Stacker Join Date: Jun 2007 Location: my mom's basement
can I get a quick rundown on how to use the rods like those from depot? I bought some but havent figured out how to use them yet. I am looking here first before I just go and ruin a bunch of stuff. thanks |
07-01-2007, 09:50 PM | #19 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
The Harris Safety Silver 56 is the easiest to use, and most recommended around these parts. Frankyrizzo may be the first person I have ever heard of using the Bernz rods with any success. I have used them for about 10 minutes, and moved on to something else. I just couldn't do anything with them.......................maybe I wasn't holding my tongue right, or maybe just didn't give them enough of a chance. Available at Home Depot also are the Lincoln Electric brazing rods, which I have had nothing but success with. Try out a few different brands/types, and see what works best for your speed, heat, and style. |
07-01-2007, 10:01 PM | #20 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
I just need more practice with the safety silv. I agree it goes on like butter when I can actually get it on. | |
