04-23-2007, 02:58 PM | #1 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
| Milling Delrin on a drill press
I've got a project that I want to start work on that will require me to do some mill work on Delrin sheet stock. The stock will be anywhere from 1/2" to 1" thick. I already have a 12" benchtop drill press and have a cross-slide vise on order. Can this be done safely with a drill press? I do not have access to a mill nor the funds available to purchase one. Thanks in advance, Ethan |
04-23-2007, 04:23 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Does the drill press have a tapered spindle, or a drawbar? If it's just a press fit taper spindle, it may pull the chuck out of the spindle if you try and mill with it.
04-23-2007, 04:44 PM | #3 |
This is gonna sound kind of lame but, I haven't even unboxed it yet. Still looking for a place to set it up. Looking over the specs in the manual though and it looks like it has a tapered spindle that is keyed at the top, where it connects to the drive assy. What exactly is a drawbar? |
04-23-2007, 04:48 PM | #4 | |
04-23-2007, 05:10 PM | #5 |
Well, I guess I could give it a try on a practice piece to see if it will work. Thanks. |
04-24-2007, 06:27 AM | #6 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I've done light milling operations with my drill press and a 2-axis vise. Mostly aluminum. My press has a tapered spindle, no drawbar. I've never had the chuck come off. I just have to be careful not to bind things up. Working with Delrin I think you'll be fine as long as you use good judgement and don't force things... |
04-24-2007, 09:25 AM | #7 |
Thanks for the input guys. I figured as long as I go slow and take my time, I should be okay. |
04-24-2007, 10:58 AM | #8 |
Pebble Pounder Join Date: Mar 2007 Location: Merritt Island
What type of bit would you use for an application like this?
04-24-2007, 11:13 AM | #9 |
Rock Crawler Join Date: Apr 2004 Location: toolsa, jokelahoma
a 2 flute mill bit will work best imo
04-24-2007, 11:24 AM | #10 |
I was checking the McMaster site and found a couple of different options. They have a vibration free end mill http://www.mcmaster.com/param/asp/PS...MainWidth=1073 that I was thinking of picking up. But that does raise another question, how small is too small for an end mill? I was thinking or picking up a 1/8", 3/16" and probably a 1/4" and 1/2". The larger bits would be for clearing out the bulk of the material and the smaller for the perimeter. And I would think that I want a square end as opposed to round or ball, correct? |
04-24-2007, 01:19 PM | #11 | |
04-24-2007, 06:29 PM | #12 |
So am I correct is using the smaller end mill for just the perimeter, where I would like a smaller corner radius and the larger end mills for cleaning out the rest of the material? Thanks again for all your input. I will eventually be picking up an real benchtop mill, once I have the funds and space for one, but for now this will have to do. |
04-24-2007, 08:03 PM | #13 | |
04-25-2007, 09:57 AM | #14 |
Cool, thanks again for you help.
04-25-2007, 04:01 PM | #15 |
One last question, for now. Is this is set of end mills worth buying: http://www.mcmaster.com/ctlg/DisplCt...th=1073#scroll And would it be worth picking up a couple of the vibration free end mills, like the ones I posted a link to earlier? |
04-25-2007, 11:05 PM | #16 | |
04-26-2007, 12:41 AM | #17 |
Rock Crawler Join Date: Aug 2004 Location: Concord Ca
gone_wheelin If you are not able to do what you want in your shop, you can come down to my shop and use the mill. It is a little drive but you are welcome.
04-26-2007, 09:39 AM | #18 |
Bender- Thanks. I will hold off on the vibration free bits for now then. Randy- Thanks for the invite. I might just take you up on that offer if this doesn't work. You going to the two-day race in May? |
04-26-2007, 10:54 AM | #19 |
I am putting on a boat race that weekend. It is the my favorite thing to do in RC. sorry I have not been able to go to GP or ROCKS in a month and I am getting withdrawls!
04-26-2007, 12:24 PM | #20 |
Is it both days?
