06-04-2007, 10:44 PM | #1 |
Pebble Pounder Join Date: Apr 2007 Location: Pacific Ocean
| Need a Brazer any suggestions???
I was going to buy a tube chassis, but then I though "what the hell, I will build my own." I am looking into getting a good brazer. Does anyone have any suggestions on which one to get. Also I know to get brake line, but do I really need a tube bender to bend the stuff? Any Help and/or Suggestions are Appreciated! |
06-05-2007, 08:59 AM | #2 |
Quarry Creeper Join Date: Jul 2006 Location: Ontario, NY
MAPP Gas from Lowes. (the yellow bottle) Safty Silv56 with same white flux from Welding supplier Cheap Brushes to apply flux I tried a tube bender but didn't like it... Just used my hands. |
06-05-2007, 02:20 PM | #3 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
06-05-2007, 03:47 PM | #4 |
Newbie Join Date: Jan 2004 Location: Moultonboro
I bought a MAPP/Oxygen torch at Home Depot for about $50 and it worked fine. Ran out of oxygen before I was done, though. Since it was after store hours and I didn't want to quit, I fired up my old propane torch to see if it would work. It worked just fine. Assuming you're using Silv56, it takes a bit longer, but not much longer, and you're less likely to overheat the joint. I'm kinda thinking that was $50 I could have spent on something else, because the propane works well enough that I haven't felt a need to get the Ox refilled.
06-09-2007, 11:45 AM | #5 |
Rock Stacker Join Date: May 2007 Location: location
The small $19.99 mini torches from both Lowes and Home Depot also work well and are much easie to handle
