06-25-2007, 05:34 PM | #1 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
| Chromoly Tubing....
Looking for a good place to pick up some 3/16" chromoly tubing for a new project, I know McMasterCarr carries it but their shipping on long pieces is usually more then what the product amount is. Any other place I could look? their are a few metal shops around here that I might stop into to see if they have a distributor or something. Also, it brazes just like steel brake line right? I have heard that somewhere before, just double checking. Anyone work with it? Anything else I should know? |
06-27-2007, 10:50 AM | #2 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
I can't comment on the brazing part, but you could try onlinemetals.com
06-27-2007, 11:11 AM | #3 |
Newbie Join Date: Jul 2006 Location: blue springs
yes you can braze chromoly. the only thing that you can't braze is aluminum
06-27-2007, 11:22 AM | #4 |
Pebble Pounder Join Date: Mar 2007 Location: Merritt Island
Just doing a quick search on Google shows a good many folks brazing Chromoly 4130, but there could be several other considerations to take into account, such as if it is normalized or not?
06-27-2007, 11:22 AM | #5 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
Chromoly? Cool. Keep us posted on how it goes. Im curious what the benefit over stainless would be? I assume lighter weight?
06-27-2007, 11:43 AM | #6 |
Quarry Creeper Join Date: Mar 2004 Location: Massachusetts
I picked up 3/16 .035 wall 4130 tubing from my local steel supply for about $1.50 per foot. As far as silver brazing the material, it just needs a little more heat because of increased wall thickness. The nice thing about using this tubing is that you dont have to clean the galvy coating off before brazing it. Last edited by kona_joe; 06-27-2007 at 12:00 PM. |
06-27-2007, 12:08 PM | #7 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Not sure I'd want to go thinner for long term durability. Did you find the chromo to be significantly stiffer then the brake line....like stainless is? Jay | |
06-27-2007, 12:13 PM | #8 |
Does Chromoly rust like mild steel or is it more like stainless?
06-27-2007, 12:26 PM | #9 | |
Yes it can rust like regular steel | |
06-27-2007, 02:31 PM | #10 | |
No, I have just had a bad run of crappy alloys in the brake tubing I usually buy, most of it will not braze at all. Looking for something different. Who says you can't braze aluminum? | |
06-27-2007, 03:52 PM | #11 |
06-27-2007, 04:12 PM | #12 |
D-Trail12... now a D-Trail11 brazing AL is just like brazing steel... yes you do need a special braze rod. This joint is as strong as a steel brazed joint. |
06-27-2007, 05:50 PM | #13 |
What type of brazing rod have you been using for Aluminum?
