08-25-2014, 01:11 PM | #301 |
Pebble Pounder Join Date: Feb 2013 Location: Mid Missouri
| Re: Brazing Video
Seems basic, & not far off from solid rod/welding prep other than #5, I would not have thought about that.
08-25-2014, 02:18 PM | #302 |
Rock Stacker Join Date: May 2008 Location: Des Moines
| Re: Brazing Video
pretty much, just more sensitive to contamination.
11-10-2014, 10:03 AM | #303 |
Quarry Creeper Join Date: Oct 2014 Location: Barre
| Re: Brazing Video
Great thread. Thanks so much for all the info here! Quick question: are you guys using shaded goggles for an oxy/map mix? I have always used these in the past (safety first!) - but I'm having a hard time spotting the flux/steel turn color, which I'm finding critical to know when it's ready for the silver. Appreciate the help. |
11-10-2014, 12:09 PM | #304 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: Brazing Video
always wear goggles. i use mapp so it doesnt heat that much. you shouldnt' need a hot red glow , so you should be ok with just safety sunglasses i would assume. |
11-10-2014, 12:21 PM | #305 |
| Re: Brazing Video
Thanks for the reply. I figured as much. My goggles flip up - I think that will work out best.
01-20-2016, 11:54 AM | #306 |
Newbie Join Date: Jan 2016 Location: Grand Rapids
| Re: Brazing Video
Anyone know if the Oxy/Map tanks on a Bernzomatic Oxy/Map torch kit can be swapped out for something larger? I was gifted the kit a while ago, but the tiny tank's are a P.I.T.A.
01-29-2016, 09:12 AM | #307 |
Moderator Join Date: Jan 2004 Location: chicago
| Re: Brazing Video
^ ive wondered the same. i like my little oxy/mapp torch but those little 1lb o2 tanks fizzle out in a hurry.
07-15-2016, 04:21 AM | #308 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Brazing Video
is the video still available? I looked on 1st page and I think its gone? ty |
01-06-2018, 04:24 PM | #309 |
Pebble Pounder Join Date: Jul 2006 Location: Sacramento, Ca
| Re: Brazing Video
without reading every post on here I was wondering if someone could answer a simple question. I need to use screws to hold a few part needing brazing to a fixture. I was going to use aluminum screws so they don't get brazed too. what does everyone use in this situation. I wonder if titanium screws could be used? thanks in advance
