11-05-2007, 04:09 PM | #41 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
11-05-2007, 05:01 PM | #42 |
RCC Addict Join Date: May 2006 Location: Roseville
*sigh* Seems you forgot that pic... (not that I needed it) Thanks for the video. If you still have the raw footage, you can send it my way and I can clean it up for you (might not be as sharp as Mr Pink's, but that depends on your camera). I do video editing/web encoding for a living. |
11-05-2007, 07:58 PM | #43 |
Quarry Creeper Join Date: Mar 2004 Location: Massachusetts
Do you heat and apply silver brazing alloy to the other side of the joint? It looks like your only melting it onto the tubing?
11-05-2007, 09:33 PM | #44 |
Quarry Creeper Join Date: Jun 2005 Location: in the middle of the pacific ocean
11-06-2007, 08:07 AM | #45 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
If you look at the back side of your joint and see that braze has not flown in there, one; you are not heating the joint evenly or enough, and two; you need to rebraze it from the back side. it takes some pratice, I still do some sh!t brazes now and then. Also, make sure your flux liquefies and flows into the joint before you apply the braze, this will ensure a total bond. stay safe kiddies. p!nK | |
11-08-2007, 02:11 PM | #46 |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
simple, yet effective! I like it. The way you made it sound, I thought the vid would be 10 minutes long, but 20 seconds is all it takes! Thanks! |
11-14-2007, 09:03 AM | #47 |
Rock Stacker Join Date: Nov 2007 Location: Clifton, VA
Thanks for all the posts Mrpink. I am inspired. |
11-14-2007, 06:23 PM | #48 |
Newbie Join Date: Apr 2007 Location: davenport
good simple stuff !
11-17-2007, 04:09 AM | #49 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
i need one of those tips for mine. i cant seem to get it hot enough to melt the 1/8 silver 50 solder.:-(
11-18-2007, 05:36 AM | #50 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
I never could braze as good with the tubing laying on the table, as the metal it is laying on takes heat away from that joint...Also, looks like you could have "fishmouthed" the tubing better in that first and 2nd pic. Looks like to much of a gap on the inside |
11-18-2007, 07:35 AM | #51 | |
11-19-2007, 07:44 PM | #52 |
Quarry Creeper Join Date: Oct 2006 Location: where fear and common sense don't get in the way
11-19-2007, 10:04 PM | #53 |
what diameter solder are you using? i got some thick stuff that i cant hardly melt now. 3/32 i think it is.maybe 1/8. close to it. just using mapp gas with the stock head. not to adjustable.:-( |
11-20-2007, 03:06 PM | #54 |
I haven't seen anything but 3/32 or 1/16. but it should say it on the canister in came in. Well is it harris or something else. can you post a pic of what you have? I've never had a problem with my unadjustable heating torch. The only other time I use anything else is with thicker material that takes forever to heat up with just a normal set up. Then I use the mapp/oxy mix for higher heat out put. I also try to suspend my pieces above my metal table so the aluminum doesn't take some of the heat. |
11-20-2007, 03:17 PM | #55 |
can't find the raw footage but I plan on making another soon hopefully I'll get a better out come or visually be able to see it better. sorry about the pic other things came up and I just forgot about it. |
11-20-2007, 05:22 PM | #56 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Ok guys, I merged your 2 brazing video threads together and made it a sticky. You can keep adding to this thread with more tips/tricks. |
11-20-2007, 05:26 PM | #57 |
Thanks Bender I think this will help alot of folks out. Jj |
11-20-2007, 08:03 PM | #58 | |
btw. this post is exactly the chatter I am talking about removing. | |
11-22-2007, 01:38 PM | #59 | |
sorry for the bs Mrpink. i dont have the adjustable tip. it is low flame. should be the problem i thnk.lol | |
11-23-2007, 05:09 AM | #60 |
Quarry Creeper Join Date: Nov 2004 Location: Fenton, MO
This seems very much like 'sweating copper' without the risk of leaks. Thanks for all the great info. I was really getting tired of burning my tube with my mig. |
